Network performance with aging routers:
I have been running my ASUS RT-AC66U Router for the past 6 years or so. The past 4 years with a Comcast XFinity Cable internet connection that was giving me a maximum Download Speed of about 120 MBps and MAX Upload of about 10-12 MBps.
Lately, for the past few months, I have been having increasing problems with my radio, and other equipment on the network randomly disconnecting, bogging down, and having intermittent communications issues.
Last night I tested my network speed and only measured about 50-60 MBps.
This morning I replaced the aging ASUS with a new IQ Router IQRV3. It was reasonably priced ($119 plus tax at my favorite online retailer)
It only took about ten minutes to get it installed (Including winding three turns of the power cable through a MIIX-31 Ferrite Snap-on)
WOW!
My Internet speed, tested with XFinity's SpeedTest jumped from my previous high of about 120 Mbps to 261.4 Mbps!
OOKLA says it is about 264.7
UPLOAD Speed on both is between 8-12, which is not great, but plenty good enough for SmartLink work!
My Buffer Bloat, measured from this website: https://www.waveform.com/tools/bufferbloat
after only about an hour with the IQ Router's automated Traffic Management system, I am getting this:
Heavily used equipment that is exposed to random static discharge via cable, phone or other outside lines DOES experience component and software deterioration, and performance can suffer. I had tried resetting the router, reloading firmware, and other things, which did not help.
If your network is getting "flakey" it may be your network equipment!
I had been contemplating updating my router for a couple of years, off and on.
All I can say now, it: "Why did I wait so long?"
Hello I am using the ASUS RT-AX82U router and love it.0
I do not understand I am told by FRS that the radio does not need all that much bandwidth but with 1 gig hub with only the flex equipment on it when changing bands I still get a delay on the radio screen updating especially when switching bands like ft8 sometimes up to 1 minute before it responds at this time I dropped 5 packets out of 9 million.
The other thing that people overlook is PC CPU and number of cores. I helped one customer recently that was having similar delays with FT8, CW chopped characters, and such. He was trying to decode four bands of FT8 at once and decodes were still populating when next cycle started populating. He was seeing on average of 12 decodes on a crowded FT8 band. This was on an i5 4550 CPU. That is a 4th gen CPU with four cores. He had 16 GB RAM. He was trying to decode four streams of data at the same time on 4 core CPU.
He upgraded to an i7 12700 with 32 GB RAM. He called me back to thank me. He said it is a night and day difference.
While SmartSDR does not need a lot of bandwidth to run or CPU or memory to run, it is sometimes the other ancillary software running on the same PC.
Also, this morning I replaced my ISP’s fiber gateway/router/WiFi extenders with the Eero Pro 6E mesh system. I had them place the gateway into bridge mode and disable the internal WiFi. Configured the Eero mesh.
Ran the test Ken referred to while my wife is streaming a 4K movie off HBO MAX. Here are the results. I haven’t tried tweaking anything yet. This was ran from my iPad Pro.
Reason for upgrade to Eero was ISP gateway did not support DHCP reservations.
73 Dave wo2x
I have 8+ years old Netgear router, Comcast 200/5mbps. Works as new.
Hope your messages not going across that everyone need to upgrade they routers/switches.
KN7K
No.... But if they are having increasing instances of random issues, disconnects, and other network performance issues, it may be their network equipment, as it was for me......
Ken is correct. It depends on several things, any one might not cause an issue but cumulatively can add to a bad user experience.
Network issues including congestion and buffer bloat is one of the things to check if you are experiencing disconnects.
Lack of PC resources (CPU cores, RAM, background programs running) would be a good place to start if experiencing radio sluggishness such as chopped/slurred CW, poor WSJT-X decoding, etc.
Just adding our experiences which may help others troubleshoot if they have issues.
There are plenty of Flex users who have older and moderate computer and network hardware which do not have problems.
And a note about the test site Ken posted. It is in California. I am in NJ. I have **** routing between myself and the test site. So my results are not as good as people in the Midwest or west coast
I had a 4-year-old ASUS router. It was reliable but connections across rooms were poor.
I replaced it with Google Mesh with 3 units. Initial setup by phone app very fast. Range phenomenal - distances up to 600 ft easy. But DHCP and forwarding setups are a nightmare. It is all by phone. You do a static DHCP and nothing changes despite reboots. But 2 hours later it is working. And then port forwarding that sometimes works sometimes not. I went on a 1-month overseas trip hoping to be able to use my station remotely, and the internet power switch would not work despite mesh reboots. It started working magically when I came back.
Perhaps the trouble is with Google, which wants to do everything by phone app where screen space is limited.
Ignacy NO9E
I just installed the Eero Pro 6e 3 unit system. Covers both levels of house plus deck. I get full speed up and down on wired ports of remote units (300/300 service) and around 280/280 on WiFi.
They use the 6 GHz channel as backhaul between units.
reason was my ISP’s fiber gateway does not support DHCP reservations.
I have been running Bufferbloat tests for a few years now, and usually I am at A grade when running the test with the computer attached with tp cable, and often B grade or worse when using WiFi. My connection is FTTH (fiber to home) and 100/100 Mb. The router is a Mikrotik RB4011 and I have a fiber from the router down to the incoming "router" that is supplied by the provider. I had to use a TP-cable to fiber converter at the incoming end, as there is only TP option for the user, but my Mikrotik offers a SFP port. This gives me less copper cable (20 meter), and galvanic isolation, and hopefully less RFI :)
I just set up the router to use a simple queue to see if it would improve the latency. As I usually see 80-100 Mb when testing, I did set the limit to 70 Mb. Tested this using my Dell laptop using WiFi and a congested 2,4 GHz. Surprised to se a substasial improvement, and for the first time I do get A+ grade when testing! The morale is one does not need the "coolest/newest" h/w but need to be able to understand how to configure it :) But honestly I'm not sure I will notice any difference between grad A and A+.
Now that the Eero 6E Pro has been running a few days the QoS has been adapting to my network. This is taken in the PC that is currently running SmartSDR connected to my radio. 300/300 ftth.
I use Google Mesh at home. Just make sure you run the Mesh in bridge mode and you don't have to worry about DHCP or port forward issues.
If you don't do that, then you have to operate in a double NAT'd mode and that is painful.
Mike,
I am using the default. The main unit is in NAT mode, and the **** units are in the bridge mode. Is this OK?
After coming back on a trip and turning all entries on the power switch manually, the power switch works well. I set it up so that after a power failure it restores its previous state rather than set all devices off.
Ignacy NO9E
Default mode is not in Bridge mode. Is the master device also connected to a Router? If so, then you are double NAT'd.
I take a dabble at this my Router was state of the art 2 years ago.
> @Mike-VA3MW said:
> @Ignacy
> 73
Hello Mike
I have a google mesh.
I have enabled UnPNP on my router, Also upnp on my Mesh.
Still unable to set up smart link .
I got the ports 4994 TCP and 4993 UDP, and tried manual port forward, still not connection.
When i go into the advance setting in the mesh and try to see for Mode, NAT vs Bridge, i am unable to set it up, as it mentions mode has been setup automatcally.
I have opened up a ticket, and awaiting a response
What am i doing wrong.
I have windows 11, Smart SDR 3.5.9,
Please help
Jith0 -
ground control to ken sounds like the the problem i have with 3.5.9 install
One comment on router performance.
Some software enables the packet inspection / QOS option by default. If it is enabled, it consumes a large number of CPU cycles. This can slow router performance (speeds) down greatly. I've seen a router go from 1gbps speed tests to 300-350mbps. Sometimes this option to disable packet inspection is known as Cut-Through-Forwarding (CTF) although it has other names/check boxes. Once enabled, the more packet inspection functions you have enabled, the more CPU cycles are consumed. If you are not seeing speed tests at your ISP's stated speeds, you may want to look at router options.
For Comcast, their routers are set to +20%, so if you pay for 100mbps down, 10 mbps up, you should expect to see something close to 120mbps down, 12mbps up. For their 800mbps service, you should see something like 940-960mbps down. That speed pretty much fills a 1gbps wired Ethernet link. Wired connections are the best way to test internet speeds.
i updated my router also , the ISP max 300 mps , the router has 10/100mps cat 5 cables.
This is a problem , cat6 or wifi to the radio. is better.
Do speed checks , my tv is not connected to the cat 5 anymore, it is wifi 5g way faster.
GT-AX11000 Asus
The router needs to be best and as fast as your ISP :)
Most home routers sold today have gigabit Ethernet jacks for the WAN AMD LAN ports.
Even old routers can handle quite a bit of bandwidth. Mostly the issue is if you have an older combo router that also has a wifi AP that's where the improvements have been made in the last 10 years. You really should have more than one WIFI access point. Ideally you'd have one per room but that can be cost prohibitive but you can put a few spread out into zones where they don't have to go through more than a couple of walls/floors to reach the AP. If you have more than one they also need to support wifi roaming (802.11r) which will allow devices to roam between APs seamlessly. Older device and some IOT devices don't support 802.11r so you also need your APs to support more than one SSID per AP so you can provide non-802.11r SSIDs for those old devices. I'd recommend Ubiquiti because it gives you one single management interface for all the APs and router even though they are all separate devices.
- 255 Community Topics
- 491 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 789 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 737 Genius Products
- 394 Power Genius XL Amplifier
- 256 Tuner Genius XL
- 87 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 588 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 815 Third-Party Software
