Flex 6400 and Wsjtx audio issue
OK, that helps.
The Monitor on WSJT or the Monitor on the Radio?
Yes, if you turn Monitor off on WSJT, it will not decode.
If, on the radio, then it sounds like something else is hearing the audio and you have the wrong RX input set. The monitor function on SmartSDR has no affect on the DAX audio stream required for WSJTx.
It should look like this
These are 2 different things. It is possible to share the audio with multiple devices. The DAX audio that WSJT uses is not related to the audio we use to listen to the radio.
Is this receive audio or transmit audio?
If receive, you can just down down the volume in SmartSDR.
If this is transmit audio, it sounds like you have turned on your Monitor function.
[{"insert":"If I turn Monitor off, it doesn't decode FT8. I've used it without any issues for so long, I don't recall what was on/off or the settings. \n"}]0
I didn't know there was a monitor on Radio 😁 let me check that later. Radio does key up when Tune is pushed in Wsjtx0
Genius! Mon was clicked on radio! 🙄 thank you very much !0
I actually leave the Mon function on when using WSJT-X. That way I can hear if the transmitted audio is clean.
If the audio is distorted I know to restart DAX.
Without listening I might never know...
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
