Flex 6400 and Wsjtx audio issue
            OK, that helps. The Monitor on WSJT or the Monitor on the Radio? Yes, if you turn Monitor off on WSJT, it will not decode. If, on the radio, then it sounds like something else is hearing the audio and you have the wrong RX input set. The monitor function on SmartSDR has no affect on the DAX audio stream required for WSJTx. It should look like this 1
            These are 2 different things. It is possible to share the audio with multiple devices. The DAX audio that WSJT uses is not related to the audio we use to listen to the radio. Is this receive audio or transmit audio? If receive, you can just down down the volume in SmartSDR. If this is transmit audio, it sounds like you have turned on your Monitor function. 73 0
            [{"insert":"If I turn Monitor off, it doesn't decode FT8. I've used it without any issues for so long, I don't recall what was on/off or the settings. \n"}]0
            I didn't know there was a monitor on Radio 😁 let me check that later. Radio does key up when Tune is pushed in Wsjtx0
            Genius! Mon was clicked on radio! 🙄 thank you very much !0
            I actually leave the Mon function on when using WSJT-X. That way I can hear if the transmitted audio is clean. If the audio is distorted I know to restart DAX. Without listening I might never know... 1
- 354 Community Topics
- 619 The Flea Market
- 8K Software
- 4 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 220 FLEX-8000 Signature Series
- 927 Maestro
- 898 Genius Products
- 457 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 979 Third-Party Software
