PGXL issues after 3.7.28 Utility/Firmware update.
Until two days ago, my Flex 6600-PGXL-TGXL were working perfectly. I got a notice from Flex suggesting to update the PGXL to 3.7.28. Immediately after the update, I found that the PGXL was having difficulty connecting to the PGXL Utility. This morning, when I powered on the PGXL for the first time, I was met with a black screen with a single blue dot (blue dot of death) it too two more power cycles to get the PGXL to self test and appear to be okay. Upon my initial transmissions of the day, after tuning with the TGXL, the PGXL is reporting high SWR. The antenna is resonate and true SWR is fine. The 3.7.28 update has made my otherwise stable PGXL into an erratic/unuseable 60lb box. Can someone tell me how to revert back to the previous software for the PGXL Utility and previous firmware. I want to spend no time trying to "fix" these recent issues. I have opened a ticket with Flex support.
Paul N6PSE
Paul
The blue dot is to calibrate the touch screen. It is not documented in the release notes.
Do this:
Turn off rear switch.
Hold Operate/Standby button in while turning on the rear switch. The amp will do factory reset. When it comes up to the blue dot, tap it as accurate as you can. It will repeat in different locations two more times. Then the amp will cycle and start up. Once that is done make sure you use the 3.7.28 utility to configure the amp (in Flex tab choosing your radio and the LAN or RCA keying, etc. make sure the check box is selected for whichever sides od the amp you are using (A or B).
If you had set a static IP in the amp, you will need to reset it after doing the factory reset.
Oh, and
make sure not to use the 3.6.24 utility. You should I install the PG. L utility before installing the new one.
Ken at Flex support sent me a link and asked me to perform the steps outlined on page 46:
He said that if problems persist, to conduct a factory reset and re-perform the steps on page 46, selecting save upon completion.
GM all
If you do a reset and see the flashing blue dot, it is related to part of the screen calibration.
This update fixed a number of issues with my PGXL and Tuner Genius.
I would get interlock issues occasionally I believe because of timing between my 6600, PGXL and Tuner Genius. It affected CW as well as false HIGH SWR faults.
My amplifier gain was between 12.5 db and 13.4 db. Now it is between 14 and 14.5 db. Maybe because of higher drive, it runs a lot cooler now using FT8 with high duty cycle.
I have run the station the last two days heavily mostly FT8 and some CW. It has worked great. My PGXL and Tuner Genius are in another room so I didn’t look at the touch screen.
I did the update from my operating position and it went smoothly like any other update. The software updated both the utility and the firmware. I then updated my second computer affecting only that utility.
Not one problem.
CUDOs to the design team. Great job.
Bill
W9JJB
Not one problem.
Bill
W9JJB
I did the upgrade and all went fine. I have noticed however that temperature does not display in SmartSDR anymore. Am I missing something?
KM
It does here with SSDR 3.3.33
You might try shutting down both radio and amp. Turn on the radio, then turn on the amp.
Dave, are you saying that updated utility will not longer show a Temp?
Could someone post image of PGXL utility after upgrade - in Standby and Operate, please?
I still hesitation to update and looking for post upgrade reports - running OK (with already known issues) SSDR 3.3.32 and PGXL 3.6.24.
Thank you Larry for images. Almost the same as the ver 3.6.24.
One question - where is the text coming from - "6700" on images above? Does it pull automatically or you have a window in a new Version to type? In ver 3.6.24 I have filed that empty and there is no way to type there
No idea, why you should be reminded that you use 6700.
No idea why Flex keep putting all this noise on all their devices, IP address, S/N and FW version - all should be included in "About" like any other Software. It will keep screen cleaner and that information is not essential for every day usage.
Sergey
6700 is what I chose as my radio nickname, this is found in radio setup/radio tab.
It shows radio name of the Flex as some PG XL owners have two different radios connected to the amp.
Thanks, my SSDR has my call there as a nickname, but it does not appear on PGXL ver3.6.24
Sergey
I just changed mine just to test it, I had to restart the PGXL and TGXL for the new nickname to take effect.
My PG-XL update to FW: 7.3.28 initially went smoothly, although I never saw the screen calibration, but the touch screen function worked perfectly anyway. I tested all transmit functions on the Amp and everything was working fine.
I should have left things alone but I decided to take Wo2X's suggestion above and perform the PG-XL reset process so I could calibrate the screen. I wish I wouldn't have done this! After doing the PG-XL Reset the Calibration indicators did show up on the screen BUT then I noticed when I turn my PG-XL on its display remains on the Calibration screen (all lines indicating OK), and in order to see the main screen I now have to push the Standby/Operate switch (which I never had to do before). Plus when I turn the Amp on the Fan ramps up for a few seconds, which it never did before I did the Reset. Also when my PG-XL is in operate it no longer shows up on my SmartSDR screen, so I can't use my Amp. And when I click the Operate/Stand button on the PG-XL App no longer toggles my PG-XL to the Standby screen but rather its Configuration/Calibration Screen. Perhaps FW: 7.3.29 will be coming soon. :)
I guess another Trouble Report submission is in order, and until then I'll have to see about reverting back to the previous FW version. Just freakin' lovely.
Lesson learned. If you do the FW update and it works, leave it alone.
Butch, KF4HR
I got my PG-XL FW upgrade problem resolved. I reverted back to the previous PG-XL FW, and everything began working again, then I cycled power on everything (PC, rig, amp), then reloaded v3.7.29 and everything began working normally with the new PG-XL FW.
During my above PG-XL Reset process, something I didn't realize was, the Reset process wiped out the FlexRadio Serial No. in the PG-XL App (under the App Settings). Once the Serial Number was reentered SmartSDR acknowledged the PG-XL being on or off.
Butch, KF4HR
In my upgrade to 3.7.28, I am unable to get band data. Reset the the PGXL per reset procedures in this thread. Now went from "Manual" mode to "RF Sense" Mode, but no connection to the FLEX 6600. Any thoughts on what how to resolve? Thank you. 73 Andrew W7VJ0
Reverted to 3.6.24 and all working... unclear why the upgrade doesn't ....0
Did you put in your Radio configuration in the AMP touch screen or the Windows Application.
I would defiantly go back to 3.7.28 as there was a LOT of things fixed that are pretty important to the performance of the AMP.
Go to the gear Icon on the top right then go to the FlexRadio Tab, then to the down arrow on the right side of the Serial number Line then select up the serial number of your radio and click the "Enable" box.
Make sure your IP address is shown of YOUR network.
hope this helps a bit
Why does my PGXL switch from AB to AAB mode after the upgrade to 3.7.28. My 6600 running 3.3.33 operates frequently in DIGU mode with FT8.
From the PGXL User Manual:
I observe the PGXL temperature runs higher (62 C) and the fans ramp up to high speed loud. Before the upgrade it stayed in Class AB and temperature rarely was higher than 56 C.
Bill, NE1B
Update- The PGXL only goes into Class AAB mode on 6 meters and 160 meters. 80m thru 10m go to Class AB.
This seems to be independent of Digital mode that I select in WSJT...MSK vs. FTx, but does respond to modes selected in SmartSDR on 80-10m., just not on 6 m. or 160m.
de NE1B
That is by design to get the Maximum efficiency from the MosFets at the far ends of the AMP's range.
Is it normal for the PGXL to idle at 5A? ID = 5A when in AAB? With the amp on, but no input signal the temp increases to 50C - this is in fan mode C. Also, the fan runs at B level when the amp is first turned on. I haven't noticed either behavior prior to 3.7.28 - I have just updated the firmware.
Keith - AC9S
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 775 Maestro
- 42 FlexControl
- 730 Genius Products
- 253 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
