Connect HRD Logbook with Slicemaster?
I normally use ddutil to connect HRD logbook which works fine. It looks like Slicemaster should be able to do the same but I can't get it to work. My goal is to have to only open Slicemaster for most tasks connecting with the 6600.
Does anyone have this working and can you provide some tips to make this work?
I have the HRD TCP Listener enabled and try to match the same port on HRD IP Server but no joy.
Thank you
I was using Slicemaster with HRD but had to stop because after a while the two frequency readouts would blank out, still shows connected HRD is no longer communicating with my 6700. Here are some screenshots
The above one shows the two frequencies upon a new connection via Slicemaster and logbooks logs as should but an hour or more later, they disappear. Does not do that with DDutil so I'm assuming it must be Slicemaster issue, I researched and could not find anyone with a similar issue so maybe it's my particular Slicemaster install.
Anyways to help you out with Slicemaster setup see the HRD radio pane config, the port must be the same in the Slicemaster sync tab, under HRD TCP Listener, it should be enabled of course.
Thank you! It's working. I'll let you know if I experience the same connection issue.
Sure appreciate you taking the time to provide a detailed answer.
N1KB
Thanks for asking and answering. I was just contemplating this setup myself.
You gave me some ideas.
I use HRD and have for a long time.
I have to start SmartSDR first then SliceMaster then HRD.
I have not manually setup the HRD listeners but that doesn’t mean that SliceMaster is not doing that automatically or learned from past SliceMaster setup.
For information purposes you may want to look at the SliceMaster ini file to see the various parameters.
Although you can start logbook only it has problems with starting. Starting SRD from the main app starts all the needed processes. I just minimize the rig control Screen.
Bill
W9JJB
I now have my HRD logbook connected via SliceMaster
It works wonderfully.
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
