VARA HF 4.0.6 With Winlink 1.5.33 SETTINGS
Here is the audio tab:
WSJT-X is now working. I didn't realize I had to create a PTT port. I'll try the same now with Vara
No joy..... I can only "Test" transmit in the setup for vara......If I use a PTT port there, it will not test. :(
That all looks good. WSJT-X transmits? I will need to look at my VARA config - as it is on Windows under parallels (I use a Mac), i just don’t use it too often, but it does work just fine with my 6600M.
Yes, WSJT-X is working fine now that I assign a PTT port for RTS part. Tried the same thing with Vara and it won't even test for PTT.
Here are my settings for VARA and WinLink Express, Ken - hopefully the screenshots work out OK.
First the WinLink VARA HF "Radio" settings (complete with SSDR CAT window):
Then the VARA HF "Soundcard" settings (complete with SSDR DAX window):
All settings in the Flex look correct, however, Vara HF P2P Settings box you show is not even similar to what I see in WinLink Express or varac
More info.
When running winlink express, it will connect to the TNC then time out:
YES !!!!
I removed all the TCP ports and it started working. However, the connection window keeps closing, reconnecting to the TNC, everything looks good for a minute, the it closes the window again and start over.
So, I'll just keep playing with it. I really appreciate the time you took to help.
73's
Ken - W4CCZ
Just wanted to leave one last comment to say all is working fine now and thank you for the help.
Ken - W4CCZ
Glad you got it working, Ken. Not sure why the settings windows were different :-( I tend to always have the latest versions installed. But then I use Windows rarely, only when using WinLink for communications exercises with Club members.
Trying to use VARA and Winlink with a Flex 3000. Is this possible? So far I have it "working" in that it can initiate a session, and I hear the other station responding with good signal level, but no connect. Then it times out. Are there some settings in PSDR or VARA that I need to tweak?0
Ted, you at the mercy of latency. The connection sequence requires a very quick tx/rx turnaround. Until very recently (after Flex did some work on reducing digital signal latency) you couldn’t get two Flex radios (6000’s) connecting. You need to do everything you can to reduce delays.
Of course you are using a 3000 with PSDR, so things are different, but the need for low latency does not change.
I am having the same issue Ken was having with the timeout happening then an endless closing and opening of the session window. I can't even change the center freq or calling freq or anything. It just crashes and tries again repeatedly with everything blank. The session window is frozen while this is happening, can't click File or anything? Do the VarAC settings effect the Vara HF at all?0
I have been working on getting Vara HF to work with my Flex 6500, but I am experiencing what alot of these other users are which is timeout happening after an endless closing and opening of the session window. I dont really understand what COM and TCP Ports, how many COM and TCP Ports need to be created and how these ports should be configured, as PTT or other configurations. All of the articles and videos I have watched all have different configurations that work, but nothing is working for me. I think part of my confusion is the number of Vara applications and installs that seem to do different things, but I just cant get it to work. I will continue until I figure it out. Thanks everyone.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
