Maestro WI-FI , Can it be updated to Run WI-FI 6 ?
N4ZAX - PAT
in Maestro
I replaced my TP-Link AC 1750 with a New TP-Link AX5400 that uses WI-FI 6, The Maestro WI-FI can not find my New Home WI-FI Network. My laptop has No problem connecting to the new TP-Link AX5400 WI-FI. Can the Maestro WI-FI Driver be updated to work with WI-FI 6?
Not at this time however, your AX5400 should provide backward compatibility to Legacy WiFi devices.
Thanks Mike, you are correct, only had to login into the TP-Link AX5400 and turn off the Smart Connect Function and use 802.11b/g/n mixed wireless mode. All is fine now !0
I turned off Smart Connect on the TP Link and the Maestro still cannot see the WiFi. Now what?0
I have the same issue. I can put my EERO in legacy mode but then it drops my speed down on everything. Is there a work around for this? Mike you said "not at this time" does that mean this could be a software update, or will this have to be a hardware update?
- 394 Community Topics
- 670 The Flea Market
- 176 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 80 Aurora
- 321 FLEX-8000 Signature Series
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
