Maestro WI-FI , Can it be updated to Run WI-FI 6 ?
N4ZAX - PAT
in Maestro
I replaced my TP-Link AC 1750 with a New TP-Link AX5400 that uses WI-FI 6, The Maestro WI-FI can not find my New Home WI-FI Network. My laptop has No problem connecting to the new TP-Link AX5400 WI-FI. Can the Maestro WI-FI Driver be updated to work with WI-FI 6?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsNot at this time however, your AX5400 should provide backward compatibility to Legacy WiFi devices.
Thanks Mike, you are correct, only had to login into the TP-Link AX5400 and turn off the Smart Connect Function and use 802.11b/g/n mixed wireless mode. All is fine now !0
I turned off Smart Connect on the TP Link and the Maestro still cannot see the WiFi. Now what?0
I have the same issue. I can put my EERO in legacy mode but then it drops my speed down on everything. Is there a work around for this? Mike you said "not at this time" does that mean this could be a software update, or will this have to be a hardware update?
- 402 Community Topics
- 694 The Flea Market
