Brand new AG - power plug doesn't fit?
n8wrl
n8wrl Member ✭✭
Just took delivery of my AG this week. Sat down last night to get it hooked up and configured. The power plug it came with doesn't fit - it's as if the center pin is too big. Spec is 2.1x5.5mm - I've tried several others with the same result.
Has anyone else encountered this?
I've logged a support ticket...
Thanks, and 73!
-Brian n8wrl
  • David Decoons, wo2x
    Hi Brian
    a support ticket is the way to go. I did not have that issue but have had my AG for almost two years.
    Just a point of reference- center pin is positive
    Also current draw is rated at 330 mA and they recommend a 1 amp fuse inline.
    Thanks for the update Brian - in case others run into same problem.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Hi Brian,
    Why not just replace the connector on the existing power supply cable?
  • n8wrl
    n8wrl Member ✭✭
    Thanks for the response. Geoff! That's what I'm going to do. I was puzzled, though, because of the published specs and the cable supplied with the switch didn't fit. Was there something wrong with the switch? Turns out no, just a change in manufacturing got ahead of the docs and the included accessories.
    So now I am going to swap out the connector.
    73!
    -Brian n8wrl
  • Geoff AB6BT
    Great, I'm happy to hear that you have a straightforward solution.
    Oh well, that happens and it is difficult to keep the docs current especially if the supplier doesn't inform you of a change in hardware.
    Good luck with the swap.
    Sorry about the change. It was a surprise for us at well.
  • n8wrl
    n8wrl Member ✭✭
    Mike please do update the product description. As of 8/20/22 it says
    • "Requires 13.8-VDC power supply (2.1mm x 5.5mm)
    Next it also says
    • Power Consumption: 13.8-VDC @ 300mA.
    Perhaps that needs to be updated to reflect wo2x's notes?
  • Mark Griffin
    Mark Griffin Member ✭✭✭
    The one problem I see with the power cable on Amazon is that it is only 6 feet long. I would definitely need one about 20 to 25 feet long. I guess I would have to get a specialty cable made.
    Mark Griffin, KB3Z
    Order the connectors and make your own or order the cable from Amazon and splice it to extend. Don’t forget fuse protection.
    I use a RigRunner 4005 with appropriate sized fuses for my low current stuff. Radio power cable direct to power supply.
