Flex-6700 on 2 remote sites with one SmartLink account
Roli_HB9BAS
Member ✭
I have two remote sites with one Flex-6700 on each side. This works fine with separate SmartLink accounts. Now I removed one account and put both radios on the same account. When starting SmartSDR both radios are seen. But only one radio can be connected. The one which I moved to the common account is not connected. SmartSDR displays an error message, but no information why it cannot be connected. Do I need different ports for the radios?
Thanks for any ideas.
73, Roland HB9BAS
73, Roland HB9BAS
We have over a dozen radios on one account without issue.
What you can't do is use the same PC to connect to 2 radios at the same time.
Can you share a screen shot or video of what you are trying to do?
Hi Mike,
Thanks for quick reply. Problem is solved.
Was a router which has problems with „static“ DHCP.
As often, two issues at the same time.
I changed SmartLink account and router changed IP address.
Thanks again.
73 Roland
HB9BAS1
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
