Flex-6700 on 2 remote sites with one SmartLink account
Roli_HB9BAS
Member ✭
I have two remote sites with one Flex-6700 on each side. This works fine with separate SmartLink accounts. Now I removed one account and put both radios on the same account. When starting SmartSDR both radios are seen. But only one radio can be connected. The one which I moved to the common account is not connected. SmartSDR displays an error message, but no information why it cannot be connected. Do I need different ports for the radios?
Thanks for any ideas.
73, Roland HB9BAS
73, Roland HB9BAS
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsWe have over a dozen radios on one account without issue.
What you can't do is use the same PC to connect to 2 radios at the same time.
Can you share a screen shot or video of what you are trying to do?
Hi Mike,
Thanks for quick reply. Problem is solved.
Was a router which has problems with „static“ DHCP.
As often, two issues at the same time.
I changed SmartLink account and router changed IP address.
Thanks again.
73 Roland
HB9BAS1
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
