Remote Smartlink connection changes local use band
Ray
Member ✭
Previously when my 6600M was used with Smartlink remotely by a friend I just saw when he connected and when transmitting. Now when he connects my local connection moves to the same band and mode that the remote is on. I can then move to a different band but when he changes bands again the local connection is back on the same band as he just moved to. What am I doing wrong? Thanks in advance for advice on how to fix this.
Ray K9RS
Ray K9RS
Are you using FRStack or any other software connected to the radio?
Not using anything else right now. I have been running N1MM and WSJT-X and leaving the local on 6 meter FT-8. After doing that for several months I noticed the local frequency changing whenever Smartlink was used. I then stopped running N1MM and WSJT-X thinking it might have been related but no luck. I am running v3.3.32.0
For some reason, the radio is doing as it is told, we just need to figure out who is telling it to do that.
When SmartLink is used at the same time, that is a MultiFlex session and is handled uniquely and isolated from the 1st session, just like having 2 radios.
It sounds like you have SmartSDR CAT on the SmartLink session associated with the 'client' of the local session. You can decide which client to connect to on this drop down.
In your case, you want to use the 'client' you are using on SmartLink. This is the name in the bottom of SmartSDR. It is called the Station Name. Free free to click on it to change the name in SmartSDR.
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 58 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
