Remote Smartlink connection changes local use band
Ray K9RS
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsAre you using FRStack or any other software connected to the radio?
Not using anything else right now. I have been running N1MM and WSJT-X and leaving the local on 6 meter FT-8. After doing that for several months I noticed the local frequency changing whenever Smartlink was used. I then stopped running N1MM and WSJT-X thinking it might have been related but no luck. I am running v3.3.32.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsFor some reason, the radio is doing as it is told, we just need to figure out who is telling it to do that.
When SmartLink is used at the same time, that is a MultiFlex session and is handled uniquely and isolated from the 1st session, just like having 2 radios.
It sounds like you have SmartSDR CAT on the SmartLink session associated with the 'client' of the local session. You can decide which client to connect to on this drop down.
In your case, you want to use the 'client' you are using on SmartLink. This is the name in the bottom of SmartSDR. It is called the Station Name. Free free to click on it to change the name in SmartSDR.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
