Does the Flex Control unit work on ios Mac?
I just my new Flex control unit and it doesn't seem work on my Mac. Is it only for windows?
Welcome!
  • Member ✭✭✭
    You have to enable the FlexControl via Tools->Controller->FlexControl.
    I've sold my FlexControls long ago so I'm making the assumption that this works.
  • Member ✭✭
    Thank you responding. I enable Fex Control in Tools and still doesn't work.
  • Member ✭✭
    It shows it is connected.
  • Member ✭✭✭
    I would attempt to use it with SmartSDR for Windows as a sanity check that the FlexControl is operational. If it is, I would connect it to the Mac (not the Flex radio) and reboot everything, Flex and Mac.
    I believe you have to Edit the mapping in the FlexControl setup page and make the associated assignments.
    I use the Midi Controller option and it works a charm ...
  • Member ✭✭
    Sometimes, although SmartSDR for Mac “sees” the USB Flex Control as being connected looking at the drop down menu, I have to physically disconnect the controller and plug it back in to have it operational. A reboot might do the same thing. It especially gets confused with I go between SmartSDR for Mac and SmartSDR for Windows (using Fusion Virtual Machine).
    You probably tried this, but I thought I’d throw it out there. It definitely works.
    Mark - wd9jen.
  • Member ✭✭
    I got it working by changing selection to “usbModem14301” under device in Flex Control. Thanks for all the suggestions.
  • Member ✭✭✭
    I was going to suggest that except you mentioned the status showed 'connected'.
  • Member ✭✭
    Can we get a direct answer? Does the Flexcontrol knob work on iOS? I can plug it in to my iPad Pro with a USB-C adapter, but can't seem to get it to work with SmartSDR.
  • Member ✭✭✭✭
    Direct Answer.
    Does a Flex controller work on Mac Smart SDR? - yes.
    See all of the responses above, for how to make it work.
    Alan. WA9WUD
  • Member ✭✭✭
    edited June 2022
    Not quite direct enough ....
    They are asking about FlexControl working in iOS (on an iPad) not SmartSDR for Mac.
    You can buy add-on tools that support several of the popular MIDI rotary tuning devices (Behringer...) and a snazzy Bluetooth control. I see no mention of the FlexControl.
  • Member ✭✭
    I think I have the same problem, for which none of the solutions above have worked. I'm transitioning from SmartSDR/Windows 10/ Parallels 11 / Macbook Pro Mojave to SmartSDR for Mac / Macbook Pro M1 Monterey and am trying to get FlexControl to come up in the new configuration. It is plugged in directly to the macbook using a USB-B to USB-C converter plug (the FlexControl & converter worked in the previous setup). Under FlexControl Settings Enabled is checked and Status is "Connected under Bluetooth-Incoming-Port". I've also tried everything with the only other option "USBmodem1101" to no avail) I edit the mapping as shown in the attached picture. Click done. Nothing works. Unplug and replug the FlexControl - nothing. Close and reopen SmartSDR for mac - nothing. Close everything and reboot the M1 - nothing. Ideas?
    thanks,
    Ken
  • Member ✭✭
    Problem fixed through fiddling and use of usbmodem1101 for device setting.
Welcome!
