Backup Configuration does not work, any fix?
Joe K7KCE
I am a new Flex user with a secondhand 6400. I reset the radio to factory defaults and have spent a few days using it and setting it up. Great rig.
I am having an issue with the "Backup Configuration" button in the radio settings. It stays on "Downloading Configuration" indefinitely. I've let it run for 15 minutes but no download occurs and I have to cancel out. Any tricks to getting this to work?
Marcus got back to me. It may be a bug. He suggested to try it repeatedly until it works. It worked the 3rd time for me.0
This does work. What version of Windows are you using and is it 'up to date'?
I'm using SmartSDR for Mac, ver 2.1.0.6 which is the current version. It might be a bug but I'd thought I'd ask here first to make sure I'm not just doing something wrong. Firmware is 3.2.39, connecting over the my local network to the radio.0
I'm having the same problem. Running MacOS 12.3.1 Monterey; and SmartSDR for Mac version 2.1.07, Firmware version 3.2.39.0
you probably want to contact Marcus for the MAC version
I have contacted Marcus. I'll post any learnings here.0
It turns out the solution (work-around) is pretty simple, just cancel the first attempt and try it again. I was rewarded with an immediate request to choose a location in which to save the file. Which it did. Marcus said he'll look into why this is happening.
Emmett W9EMY0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
