Backup Configuration does not work, any fix?
Joe K7KCE
I am a new Flex user with a secondhand 6400. I reset the radio to factory defaults and have spent a few days using it and setting it up. Great rig.
I am having an issue with the "Backup Configuration" button in the radio settings. It stays on "Downloading Configuration" indefinitely. I've let it run for 15 minutes but no download occurs and I have to cancel out. Any tricks to getting this to work?
Marcus got back to me. It may be a bug. He suggested to try it repeatedly until it works. It worked the 3rd time for me.0
This does work. What version of Windows are you using and is it 'up to date'?
I'm using SmartSDR for Mac, ver 2.1.0.6 which is the current version. It might be a bug but I'd thought I'd ask here first to make sure I'm not just doing something wrong. Firmware is 3.2.39, connecting over the my local network to the radio.0
I'm having the same problem. Running MacOS 12.3.1 Monterey; and SmartSDR for Mac version 2.1.07, Firmware version 3.2.39.0
you probably want to contact Marcus for the MAC version
I have contacted Marcus. I'll post any learnings here.0
It turns out the solution (work-around) is pretty simple, just cancel the first attempt and try it again. I was rewarded with an immediate request to choose a location in which to save the file. Which it did. Marcus said he'll look into why this is happening.
Emmett W9EMY0
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 148 FLEX-8000 Signature Series
- 904 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 713 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 935 Third-Party Software
