Boot up problem
KB4OIF
I have a problem with my 6600M booting up. The power button flashes 4 times and it will not boot up. I have seen a chart that says what it is on here somewhere, but can 't find it. I
What colour is the led button when it flashes?
Check your power supply voltage. 4 red flashes indicates an overvoltage condition.
If the voltage is in spec (13.8 VDC +/- 15%), you should probably submit a help desk ticket.
When the red LED on the front of a FLEX-6400/FLEX-6600 blinks four times, it is an indication that the voltage input to the radio is over the threshold (16V). Power control will remove power from the radio and wait for a restart.
You need to check your power supply voltage.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
