Don't do what I did...
I had some minor problems upgrading my 6400 from 3.2.39 to 3.3.29. I was ultimately able to get it to load, but I realized that I left an active session of 3.2.39 running when I did the upgrade (this is far from my first upgrade, I have no idea why I did that...).
To test my theory as to the cause of the problem, I downgraded to 3.2.39, then shut down SmartSDR and upgraded to 3.3.29. Absolutely no problems - it upgraded perfectly. So don't do what I did... Make sure that SmartSDR is shut down before upgrading. @Dan Quigley, N7HQ - Another data point Dan...
While I had the older version running, I compared audio from an analog rig to my Flex. The latency was what I have come to expect - very apparent, but not show-stopping. After upgrading I compared again, and now I get latency that sounds more like an echo in a big room instead of the echo in a stadium. It is VERY much improved. ALE and VARA operators should give this version a try to see if the TX turnaround time improvement makes a difference.
Len, As usual good and helpful comments! I'm curious are you using the original SD card that the radio came with? I read that some issues with upgrading may be related to having the original SD card, what do you think? Thank you.
W2JV Peter
Thanks Peter, I appreciate it. Yes, I have the original SD card. I got the radio with 3.1.8 and did all the updates just as soon as they came out.
I suppose that it is possible that a bad SD card could cause issues, but I doubt that it would be a common occurrence.
From reading this forum and the one on Facebook, the SD card failure is quite widespread. There are a lot of people experiencing failures rendering their radios unusable. And on top of that, the update has caused problems for people that use the internal ATU. Fortunately, I don't use the internal ATU. I do use a manual external tuner.
I hope Flex Radio learns something from this fiasco.
There is a bit more to come on the SD card issue. What I can say is that it doesn't affect all radios, but more of those are older 63,65's and 6700's (but not 100% limited to).
I can't mention the entire radio install base number, but it is a small (but vocal) percentage that is impacted. It does 'read' worse than it is (still, it doesn't help if you are impacted). We are jumping on this and people are working overtime to limit the downtime for those impacted.
Thanks for understanding.
Thanks Mike. I am glad to know the problem is not that widespread. Hopefully, that's a sign that most user's SD cards have been replaced already.
Of the several forums I participate in, there are a large number of people reporting issues with the update. It certainly pulled a lot of people out of the woodwork! How that number compares to the company's user base, is obviously unknowable since those numbers are not shared. ( and I understand why that isn't shared) I am glad Flex Radio is attacking the problem quickly.
To give you a number, it is less than 0.1% of the install base. :)
Just out of interest. What is the percentage of the installed base that has already upgraded?
I am also very curious to how long it will time for us among the 0.1% of the base to get the new card? Does FlexRadio have a line of supply for these cards so it is merely a question of copying software to them and shipping, or does it also involve a bigger logistics operation to fulfill the amounts and needs?
Last but not least. What are the chances of just distributing an image file to be able to make a microSD. A new "industry SLC" microSD with the same specs will cost me $10 here - and I belive anybody who has ever owned or installed a Raspberry pi have made their own bootable microSD by downloading and getting the files onto the SD by using standard and well known and tested tools....
You might find that the 0.1% community are among most loyal and interested users and customers, but also the ones who are particulaly able to do these simple steps. By providing this as an option, it would definately take the edge of your staff, overtime and logistics operation - and make customers happy by giving them an option to help "oneself" back on the air...
Meanwhile. I found the reference to John 3:16 on the motherboard close to the SD card. Not sure it helped, but probably didn't make it any worse either...
0.1% ? From a casual count of bricked radios I have seen posted, that put's the # of flex radios in circulation at about 30,000. Very impressive. 🙈🙉🙊
I don’t think I have seen 300 bricked radios in this forum.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
