Monitoring Transmit Audio after TX Equalizer
GM Gentlemen,
Is there a way that I would be able to monitor what my transmit audio sounds like after I would make adjustments in the TX Equalizer? I would like to test it out for the ARRL DX Phone Contest this upcoming week. Plus, is there a way to do this without actually broadcasting on the air? I just thought I would ask these couple of questions.
Mark Griffin
KB3Z
Try this:
Ronald
Ron,
So more or less I have to put my 6400M in full duplex mode.
Thanks!
Mark KB3Z
Mark just follow the video…this process has been used for years…
Ronald
Ronald,
Here is a question. I only have 1 antenna connected to port A. But I also have a receive antenna connected Would I be able to set the radio to full duplex with my 6400M and on Slice B be able to listen to the transmit frequency with my receive antenna?
Mark KB3Z
Mark,
We just did a live session on this Friday. We answer all your questions in the video.
Mike,
Yes I did watch the video. I assume that I can set Duplex through the menu system on my 6400M?
Mark
Yes, you can. Just pick an RX antenna port (Blue) that is different from your TX antenna (Red)
Thanks Mike!
Mark KB3Z
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
