Monitoring Transmit Audio after TX Equalizer
GM Gentlemen,
Is there a way that I would be able to monitor what my transmit audio sounds like after I would make adjustments in the TX Equalizer? I would like to test it out for the ARRL DX Phone Contest this upcoming week. Plus, is there a way to do this without actually broadcasting on the air? I just thought I would ask these couple of questions.
Mark Griffin
KB3Z
  • RFord
    RFord Member ✭✭✭
  • Mark Griffin
    Mark Griffin Member ✭✭✭
    Ron,
    So more or less I have to put my 6400M in full duplex mode.
    Thanks!
    Mark KB3Z
  • RFord
    RFord Member ✭✭✭
    edited February 2022
    Mark just follow the video…this process has been used for years…
    Ronald
  • Mark Griffin
    Ronald,
    Here is a question. I only have 1 antenna connected to port A. But I also have a receive antenna connected Would I be able to set the radio to full duplex with my 6400M and on Slice B be able to listen to the transmit frequency with my receive antenna?
    Mark KB3Z
    Mark,
    We just did a live session on this Friday. We answer all your questions in the video.
  • Mark Griffin
    Mike,
    Yes I did watch the video. I assume that I can set Duplex through the menu system on my 6400M?
    Mark
    Yes, you can. Just pick an RX antenna port (Blue) that is different from your TX antenna (Red)
  • Mark Griffin
    Thanks Mike!
    Mark KB3Z
