On a flex 6500 and 6700 is there a means to disable ie. turn off the front panel display?
Craig Gagner
On a flex 6500 and 6700 is there a means to disable ie. turn off the front panel display? My operating position is such that it is not used.
73, w7phg
No
I put the display as dim as it can go and turn off the button backlighting. Via the panel display "menu". When I'm controlling the radio directly rather than with SmartSDR, I use an external monitor so I rarely look at the display. Probably makes little difference as far as power consumption or longevity, but it looks better (to me) and it's easy to turn it up if I want to use the display. Mark wd9jen.0
Thank you Mark; given I operate the radio remotely I never or rarely have occasion to look at the front screen. Just trying g to minimize unnecessary wear.
73, w7phg
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
