On a flex 6500 and 6700 is there a means to disable ie. turn off the front panel display?
Craig Gagner
On a flex 6500 and 6700 is there a means to disable ie. turn off the front panel display? My operating position is such that it is not used.
73, w7phg
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsNo
I put the display as dim as it can go and turn off the button backlighting. Via the panel display "menu". When I'm controlling the radio directly rather than with SmartSDR, I use an external monitor so I rarely look at the display. Probably makes little difference as far as power consumption or longevity, but it looks better (to me) and it's easy to turn it up if I want to use the display. Mark wd9jen.0
Thank you Mark; given I operate the radio remotely I never or rarely have occasion to look at the front screen. Just trying g to minimize unnecessary wear.
73, w7phg
- 996 Maestro
