DAX
I am totally confused about a problem that I believe is related to upgrading to V3.2.34.312. In the Dax control panel, I get no slice in slice one RX stream. It tells me this channel has not been enabled. This channel has not been selected in a SMART SDR slice.
I tried several attempts to correct the issue without any success. I welcome any suggestions.
I'm using DAX v3.32.343128, CAT v3.2.34. the Flex6600M is using HW V3.2.39.3374
Whenever I upgrade SmartSDR, CAT and DAX are also upgraded to the same version as SmartSDR. I wonder if that is the root of your problem.
Do you , by ay chance, start SmartSDR without automatically starting DAX and CAT? If so, you might try setting Autostart for both, then re-start SmartSDR to see if that fixes the issue.
If this causes different versions to load, you may want to re-install SmartSDR to be sure everything is at the same level.
Hi Len, I tried your suggestions, no luck. This is a real mystery everything was working fine, turned off the radio and computer, turned them on the next day, and bad stuff!
Next step is to submit a help desk ticket. There is a good chance that the Flex folks have already seen this problem or something like it. They tend to diagnose problems pretty quickly.
Can you post a screen shot of both the SmartSDR Flag with the DAX Channel selection and your DAX panel.\
This is the first part I would check.
Mike: I honestly don't understand what happened. The problem mysteriously disappeared as it appeared.
This recalls what my Navy electronics instructor would say "if you don't understand it, it must be FM, F**king magic!
I do appreciate your reply to my SOS. I can tell you the DAX Control Panel did show "This channel has not been abled, This channel not selected in a smart SDR slice". It was yellow with no slice. Now it shows slice A streaming.
Thanks again and please leave some 6 meters FT8 DX for the left coast.
Len
Glad you got it sorted.
I have actually been beaming that way a LOT. :) I need a lot of grids out there.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
