CAT won't load on W10
I have bought a new W10 PC (Intel NUC Extreme I7).
I have loaded SmartSDR .39. For some reason the CAT program wont load, I have told Smart SDR to load CAT and DAX, DAX loads fine and I can use 6600 on the LAN. But when I manually click on CAT it starts to load and then does noting. I removed all and did a new install but same issue.
Any ideas please as it prevents me from getting the radio to talk to N1MN and HRD etc.
VK5CP
[{"insert":"Mine is doing the same thing! I'm guessing it's some kind of Win 10 safety/security thing preventing it. I tried it with my anti-virus turned off but same nothing.\n"}]0
Try this:
Intel has posted a new graphics driver today to replace the BETA version from June 8th.
I have installed it and it seems OK. I had some issues with the install due to windows defender deciding that the exe was a dangerous file. So I downloaded the zip version, unzipped it and did the install.
SSDR is running without problems. I can't test it with games as I don't have any.
This new driver corrects bugs in the original and also fixes a graphics problems in the intel 11th generation processors.
You should check the release notes and ensure your processor version is on the list. Find your processor version in settings/system/about.
Robby/HP3SS
Chris VK5CP,
I located the file FlexVCPinstaller.exe and ran it. CAT then loaded without problem.
GL 731 -
If you are still having an issue, please open a support ticket. We can sort it out for you pretty quickly and with less frustration and guessing. We don't want you to make the situation worse.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
