installing 3.2.34 on a laptop with issue
I am having difficulty, again with installing, this time with the dax drivers.
I have tried compatibility mode ( windows 8 ), as I had to in version .31, but this time, dax will not install at all. also tried the bat files, with and without admin rights, and also in cmd ( with admin mode ) but not going.... any suggestions
@Dave Garber ... It might be best to open a support ticket at this point so the guys can focus on it for you.
Running 3.2.34 on a Windows 10 desktop, I get this error message when I open the memories window.
I also get this error
Hi Jack, I would try reinstalling SmartSDR (including DAX). When you upgraded to 3.2.34, did you do a factory reset? If not, try that. Did you import any profiles from 3.2.31? If so, there is a warning that they may be corrupt. Do a factory reset and import profiles from a release prior to 3.2.31.
If none of that solves the problem, I would submit a help desk ticket.
The Maestro and a Dell laptop, I7/W10 is OK. I did make a mistake in my last post. The Desktop (I5) is running Windows 7. Both are 64bit.
Oh, OK. Well, same advice on whatever computer is not behaving. A Help Desk ticket usually gets a response very quickly, so if my suggestions don't pan out pretty quickly, the ticket is the way to go.
- 633 The Flea Market
- 130 SmartSDR+
- 197 DAX
- 41 Aurora
- 955 Maestro
