Unable to register Smartlink
KG9LD
in Networking
Hello all,
I hope I am able to avoid a help ticket and get pointed down the right path here.
I took possession of a used 6500. It does not seem to have any issues. I have it connected via a tp-link bridge that my Imac is on. I'm running the latest version of Smartsdr for Mac and have upgraded the firmware on the 6500 without issue. I am getting green lights and the Imac is running online and the radio just fine.
My problem seems to be a networking issue with the 6500 getting usable internet access. I am unable to register the radio to Smartlink. The ptt part works but it is still unregistered and the test smartlink option just hangs as though there is no internet.
I "think" I created a port forward for the lan port I'm using on the router (Uverse Gateway) and enabled DMZplus mode (allow all applications) on the router ( temporarily) to test/troubleshoot.
In preferences I have it set to Connection Type: Both, Lan/wifi mode: Discover.
The lan ip address is: 108.199.175.24 and the radio ip address is 192.168.1.103.
If I could figure out how to post screenshots here I would. I'm not real good with router settings and port forwarding but I think I did everything ok.
If you are able to help me, thank you in advance!
By the lan address, is that the address of the router?
I'm guessing it is0
@kg9ld did you get this resolved?
Yes I did Mike. It took 2 Teamviewer sessions with the guys from Flex but it's working great.
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 175 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 286 Shack Infrastructure
- 201 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
