what's the use ,can't enable smartlink remotely
This is upsetting, I have been told I have to enable smartlink at the home computer. I'm 9k miles away. So I have to suffer with using remote hams. So I have the best Radio and the Best AMP in my view point. but remotely has it limitations. Flex pats it's own back and we can remote any where , this is true till you have a maintenance issue, and have to send it back to FLEX. I hate to look a gift horse in mouth. My Radio was out of warranty and the payment for the repair says Warranty Parts SD Card. So anyone want fly on PROBO and get my smartlink up. , I'm rethinking my ham radio setup now.
Jim
WU5E
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    By “enable,” do you mean the initial setup of SmartLink? Most of us routinely operate via SmartLink from our remote laptops, Maestros, iPhones and iPads.
  • David Decoons, wo2x
    Jim
    can your wife key the mic when it gets to the point during the SmartLink registration process?
  • WX7Y
    WX7Y Member ✭✭✭✭
    I use a relay contact to key the PTT or CW Jack on the Radio to let you remotely register the radio for SmartLink
    Sorry you had issues but there is a work around for almost everything
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Normally, the smartlink setup is accomplished while local to the radio before operating remotely.
    Unfortunately Jim had a bad SD card. He was able to have someone send the radio for repair but the radio came back unregistered. Jim is away from the radio.
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
    my smartlink was setup, I was operating remote from Korea for 4 months then SD card failure back to FLEX then repaired then back to my station , now I have talk my wife to cable the radio back together and then talk her though smartlink setup again. So pray for me I don't loose my cool over this action.
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    Jim,
    That's tough duty, my only suggestion is to be very slow and very deliberate ... 🙂 She can do it for you , I am sure.
    Dudley
    Jim, you have my number. Feel free to give it to her. If she has an iPhone we can use FaceTime so I can see what she is connecting.
    @James Kennedy-WU5E
    Yes, you have to be local. This is 100% there as a security feature and we are sorry it is impacting you.
    The good news is that it is a 1 time thing. Once you get it done you should not ever have to do it again unless you change your password to your login.
    I see that @David Decoons, wo2x has offered to help. I would take him up on the offer.
    73, Mike
