SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
Vox SSB-CW
hi all
i have this problem with ssdr 2.6.2. not normal for me
Follow me: I often use the vox in ssb mode I don't use any circuit to close the PTT. Here's what happens: I'm in ssb mode on a certain freq. with vox mode active, if I change in CW mode the Vox key remains activated and when I speak alone in cw mode the radio goes into TX mode without power output. to block this inconvenience I have to return to SSB mode, deactivate the VOX and then return to CW mode.
does it happens to you too?
tnx, lou
Best Answers
Good afternoon Lou:
I can not duplicate your problem on my 6600 or 6500 radios that are using 2.6.2 . Whenever I have encountered a weird behavior from a radio , I have performed a "FACTORY RESET" and the radio has returned to the expected operation, this does not happen very often and only once with 2.6.2.
Last week the 6500 would not transmit on antenna A but would output power on antenna B. A reset solved the problem, the 6500 had not been reset since 2.6.2 was installed. The 6500 worked correctly the previous day, upon power on the following day the antenna port selection problem occurred. My 6600 has never required a reset.
If you do a reset , save your profiles and memories .
73 Gayle K0FLY
5 -
When I switch from SSB to CW the VOX button is grayed out, when I switch from CW to SSB the VOX button becomes active again (BLUE). Does this occur on all bands?
Gayle K0FLY
5
hi tnx
i did rigth now the factory reset, pressing for 5 second the power button untill it became green (flex 6400)
northing happen
i show you pics after the factory reset
Hi Lou, I cannot recreate this situation with my Flex 6400 running 3.1.12. I can clearly see that the VOX is active in CW mode in your second picture, so it looks like a real problem. It is probably time to submit a help ticket so the Flex engineers can take a look at it.
Len, KD0RC
. The strange think is that the radio in cw mode when i talk near the mic headset the flex goes in Tx with no power. While if i deactivate the vox in ssb mode and i ll be back in cw nothing happen all work.
In cw mode the vox icon is fated blue
no other one answer me, i open help ticket. i reset flex and reloaded the software 2.6.2, nothing.
hope is a bug
- 15.9K All Categories
- 63 Community Topics
- 1.9K New Ideas
- 139 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 39 SmartSDR for Maestro and M models
- 96 SmartSDR for Mac
- 144 SmartSDR for iOS
- 152 SmartSDR CAT
- 71 DAX
- 280 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 562 Maestro
- 14 FlexControl
- 729 FLEX Series (Legacy) Radios
- 161 Power Genius Products
- 124 Power Genius XL Amplifier
- 14 Power Genius Utility
- 23 Tuner Genius
- 44 Shack Infrastructure
- 23 Networking
- 95 Remote Operation (SmartLink)
- 50 Contesting
- 145 Peripherals & Station Integration
- 64 Amateur Radio Interests
- 425 Third-Party Software
