Maestro web based log on
Steve, Yes this is a limitation of the Maestro. I would have hoped Flex would have dealt with this before now!
Possible workarounds:
1. See if you can get a hardwire Ethernet connection.
2. You can also set up your own local wifi if your cell phone supports tethering ($$).
3. It's more hassle, but you could use a laptop (or Raspberry Pi!) that logs into the host's wifi and then supports ip forwarding with the Maestro via Ethernet. (May require advanced networking skills.)
This is based on my experience several years ago, but I'm not aware of any recent Flex developments in this area.
73 Martin AA6E
Wouldn't this be the same type of login at a hotel? So you would not be able to use the Maestro directly from a hotel wifi?
The Maestro is not capable of using a captive portal where you have to log on to a web page before getting access to the full capabilities of the WiFi network. The only option I am aware of is to have the MAC address of the device whitelisted on the WiFi authentication server.
all the firesticks and rokus of the world have figured this out by connecting the device to a cell phone where you auth then reconnect the device to the captive portal network after auth. Is that in the dev plan for the maestro?
Tim - Thanks.
After working with the Okaloosa County Florida EOC for over 25 years and being the ARES EC twice over the years I can assure getting that MAC on a White List will not happen. I just take my laptop with SmartSDR on it and test that next week after everything calms down some more.
Thanks all.0 -
The best solution I have found is to buy yourself a small travel wifi router. They will get you out of situations like this and many others when you cannot be sure of the network at a location that you will operate from. Here is an example of one similar to the model I have had for several years.
https://www.amazon.com/GL-iNET-GL-MT300N-V2-Repeater-300Mbps-Performance/dp/B073TSK26W0 -
I used my Samsung Galaxy S20 Plus 5G hotspot to connect my Maestro.
https://youtu.be/bPGAaXnM0M00
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 720 Genius Products
- 387 Power Genius XL Amplifier
- 249 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
