Radio Dropping off line -- solutions
Mike-VA3MW
Hi All
Occasionally I have had some issues where the radio will drop offline and personally, here is what I have done to isolate it. This is on a local connection, but it could happen on a remote connection as well.
Today was a great example. Since I totally rebuilt the Win 10Pro box from scratch about a month ago on an SSD drive, it works solidly.
But, about 1 pm today, it started to drop off every 30 minutes are so and SmartSDR would lose connection. I knew it wasn't the radio, or well, that wasn't the first place I was going to look.
After the 3rd, I had some command prompt ping windows opened on the SSDR computer and another computer so I could keep a look at multiple paths.
The next 2 times it happened (I didn't have to wait long) it was clear that it was related to the Win10 Computer, so I focused on the NIC card in that computer. Or it could have been the port on the network switch.
I had 2 computers pinging the radio. When it failed, only 1 computer could not reach the radio. This confirmed the problem was not the 6600 or its path to the switch. Remember, you have to consider the data path between the radio and the client using it.
I did 3 things at once (I know, I should have done 1, but I was watching for 6M DX and I wanted to fix it quickly).
So far, it has been 7 hours or so and rock solid again.
Hopefully, these are a few clues you can try if you keep dropping a network connection.
Remember, streaming HF data is harder on your network than surfing the web or watching NetFlix.
73, Mike va3mw
- Changed the LAN cable - yes they go bad
- Moved the LAN cable in the switch to another port
- Change the NIC Adapter settings for Speed on the PC from AutoNegotiate to 100M Full Duplex.
73, Mike va3mw
2
I would like to ask how to change to from AutoNegotiate to 100M Full Duplex. My dropouts are not as often as yours but I've had as many as 3 in one day . I bought the IQRouter but that didn't help . The past 2 days , I've rebooted the computer at noon . No dropout yet but it's to soon to know... I'm trying anything I can .
Ed1 -
Mike,
Something else is to "disable" the "Green Ethernet" and the "Power Saver" in the NIC properties both of these will cause the NIC to pause .
Dudley
WA5QPZ1 -
Dudley, is correct, many months ago, had same problem. Going into the advanced setting on the the ethernet and looking for anything that would turn the port off or put it to sleep. Now the ethernet is happy. One thing that would help us none PC admins. Would be to create a library of settings for various PC functions that are used in our everyday use of SmarSDR and maybe some of the third party apps we most commonly use.1
I presume there are folks like me who have never messed with their ethernet card or settings. There are a host of settings. I turned off the energy efficient ethernet and the green ethernet but I'm wondering if anything else should be tweaked to optimize use with the Flex? Besides the advanced options there was also a save power setting under the power management tab I turned off.
Tnx Dudley , The iqRouter is new , I'll have to do some noising around to see if it's Green plus find AutoNegotiate .
The dropout only happens on 1 of my 2 computers . I have a 6500 on the #2 computer and it never drops out but if I load it on the #1 computer it too drops out0 -
Mike and Bob
I was not sure where to look to change the settings. I had to decipher the what was written.
So for the rest of us. The NIC card is a device in the computer and can be changed by going to the Computer Control Panel and selecting Device Manager. Expand Device manager and click on the Controller (for Ethernet) Not Bluetooth or Wireless Adapter. Double click on the adapter and the properties will come up. Pick the Advanced Tab and you will see the applet that Bob shows above. When you click on the various parameters it will show you the various choices.
I changed the 3 properties that have been suggested. I have not seen the problems that have been stated but I have had behaviors in the past that I didn't see a root cause especially when running LatencyMon testing. (identified at times as NIC driver issue. Who knows.
Mike, I have been working on reliability and stability of the system for using remote as well as day to day. This may be something that would be suggested for all Flex users as a manual appendix.
Now if someone could fix the memory leak in the DAX Driver that caused the TX audio get corrupted every 2-4 days and required cycling the TX DAX button off and on to clear the problem.
Mike, Thank you for raising this setup recommendation.
Bill W9JJB1 -
Hi Ed, do you have a screen saver active on computer #1? If so, that might be the issue. 73, Len, KD0RC0
I do have occasional radio disconnect, maybe 1-2 times per month.
My 6600 runs 24h and also have DAX issues every 2-3 days and have to be restarted.
Checked above settings and I cannot find these settings on my card - "Green Ethernet" and the "Power Saver".
I did turn off "Allow the computer to turn off this device to save power" function.
Sergey, KN7K
I actually would like to see the settings for each line from the hams who does not have interrupts.
Sergey, KN7K0 -
Len no sir I do not , I have things set to were the hard drive or monitor never sleep
Ed N5DG0 -
Thanks to everyones post I found AutoNegotiate and changed to 100M Full Duplex. Now I'll let it run a few days to see
Ed N5DG
Did you change Speed & Duplex to 100m and duplex. This was a key change from Mike. 73 Bill0
Sergey,
Not all NIC LAN chips have a Green but most do have a Power Saver.. Seems that Microsoft has updated some of their drivers, and over wrote previously changed options.. I still have my "Realtek PCIe GBE " motherboard NIC doing "Auto Negotiate " for the speed settings and it seems to be running fine.. If you have a manageable switch, check for Green settings there too, made a difference on a Cisco switch that I had connected to the radio and computer.. Mine is working much better..
Dudley
WA5QPZ1 -
Bill just checked to be sure , yes Speed & Duplex to 100m and duplex.
Ed N5DG0 -
Tnx Dudley , I'm not using a switch , I have two 6xxx and 2 computers going directly to the IQRouter . The tech support person with IQRouter tells me I should have a switch with everything connected to the switch and only one cat cable from router to switch . If these changes I've made today don't help , I will try that .
What ever radio is on Computer #2 never drops out so I'm thinking it's computer #1 that is my problem and not the router. I'm still rebooting the computer computer #1 each day at noon and no dropouts now for 3 days
Ed N5DG0 -
Ive been having intermittent connection dropouts. I checked nic. Turned off windows power saving on nic. Funny thing is, i thought i'd already done that in the past. Maybe windows had changed it back with update. Dont know. I dont seem to have any of the green power settings. Set it to 100m full duplex. Ran it all night with 4 slices and 4 instances of wsjt-x. So far so good. No dropouts. Maybe that fixed problem.
Thanks for help
Wayne
VK4ACN0 -
Wayne I hope that's the fix too . I can't find the power savings either
30 hours now. No disconnect1
Ed. Im assuming some cards dont do Green. But unticking the Windows power saving box might fix the issue. Mines been on 13 hrs with no dropout. But it was intermittent so fingers crossed0
Ed
I was using my Comcast/Router with all connection .
Tim from customer support suggested a switch for the Flex related equipment including computer to reduce network traffic and latency. If was a good improvement with virtually no data errors and 1 me latency. I just looked and had 20 errors in 10 million packets. 0.00%. It was a unmanaged 1 Gb switch no programming GS108v4. 8 ports Others may have other choices but it works for me and was suggested by Tim. It was $30-40. Nethgear
73 Bill W9JJB0 -
I went and changed all the possible settings, rebooted and had no internet. I put everything back and got on no problem. I'm going to have to try changing things one at a time, but if someone has any idea why that happened to me, I'm all ears.
Thanks and Happy Father's Day to all the Dads.
73, Bob0 -
Bob
Try just the speed setting and have it match your Switch you are connected to and see how that works for you.
730 -
My PC and Flex-6500 are optically connected directly to an IQ Router. One other satellite connection direct to the router. No switch. Should I get one in the upstairs shack? The router is in the basement. I have been able to disable energy efficient ethernet and green ethernet without any problems. I should mention drop outs are not very common but do happen on a rare occasion. Thanks for the help. Bob0
Hi Bob
The IQ Router actually has a 4 Port Switch in it, so you have to consider that device as well since it is a multifunction device.
You can give the speed lock down and try. Make note of it so you don't forget.
I am able to lock down the speed. One strangeness, however. There is a Power Management tab. If I turn off "Allow the computer to turn off this device to save power" and also the "Allow this device to wake the computer." , I can get to some internet sites but not others and my Outlook email has no connection. I guess that's what caused my problems yesterday. I'm not going to worry about it. Just letting others know in case they run into something similar. 73, Bob0
Dudley, where do you find "Green Ethernet"?0
If you go to device manager, choose your ethernet adapter, right click, choose properties, go to the advanced tab, you may find it listed. Apparently, not every computer will have it.0
I'm going from bad to worse , Now the radio lost connection and nothing I can do to get it to connect . Turning it off , removing the +12 for a few minutes , add the +12v back , turn on the radio , reboot the computer and when I click on thr SSDR icon the radio pops up and go's away ... Light on the front flashes RED for about 15 seconds and then blinks green .. What A PITA . I just got this radio back from FRS last Tue for this problem0
I just did a factory reset and the radio came back up .. I had to do the same thing 14 hours ago ... Also I'm not reloading profiles , I'm building new .
Ed N5DG0 -
Thank you all for these most valuable tips regarding the Speed/Autonegotiate/ and NIC Power Saving settings. I had been experiencing multiple dropouts per day. I changed all of my ethernet cables and tried several LAN settings to no avail.
Since implementing these suggested settings, I have had no dropouts for the past 48 hours.
As mentioned, these tips should be included with a SmartSDR "Getting Started" Guide.
All the best - Hunter K3IE
- 317 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
