USB PTT foot-switch
Mike,
Thanks for getting back to me. It's not rf as I have the pwr setting at 0 for testing. I am testing it now on my lap top and have added the 20ms delay after the daxOff cat command and so far that seems to have worked. If I cant duplicate it on my laptop then I have to think something is up with my usb driver on my desktop.
I am not there yet however. Does Flex have any recommendation on the use of FIFO buffers? I currently have mine enabled but have the buffer setting at the minimum. I am not sure if I buffers are needed as I am sending 14 chars * 256 for 3,584 bytes. Also is there any issue with me editing the CAT config fie?
The main reason I want to use USB is because DB-9 ports on lap tops are non existent today. I will keep playing with it to try to get it more stable.
I am still having fun with it.0 -
Hi Mike
I can't really say as I doubt we really exploited it. I think they try to stay with the default unless there is a reason to change it. Same is true with editing the CAT config file and I would not recommend doing it as it may complicate other debugging should we have to do that.
Mike0 -
I've been using a foot switch thru USB/FTDI cable, works great.
Had to add a couple 102 caps to keep the RF demons away..
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 41 Aurora
- 955 Maestro
