Straight key with pc running SSDR remotely
johna8119
I am wondering if it is possible somehow to use a straight key with a pc running SSDR at a remote location from my 6600. I know that I could use the CWX feature, but it would be nice to use my straight key or bug.
As I think about it, I should be able to use a USB adapter of some kind to connect the key to the PC. However, I don't see anything in SSDR that would allow me to use the input for CW. Does anyone have any ideas?
John
W4KV
John
W4KV
Hi John... as far as I know, this isn't possible through a remote SSDR connection. There's no mechanism I'm aware of to access the 'key' port from the PC -- except, as you mentioned via CWX.
Don
Hi John
Unfortunately you will have to use a Maestro with the key plugged into the Maestro.
Here is a starting point. A separate software internet circuit activates the key on the Flex Radio.
Have not tried this, however, there may be other implementations as well.
https://iw7dmh.jimdo.com/older-unsupported-projects/remote-morse-key/
https://community.flexradio.com/flexradio/topics/smartlink-and-paddle-cw
Hi John, without commenting if this is possible or not (look at my post about using a paddle), to allow the radio to transmit with a straight key just disable the internal automatic keyer and use the RTTY rear connector. (SmartSDR software guide, Para 24.5)1
I think that you can use a Winkey in remote mode: http://k1el.tripod.com/WKremoteX.html
Not SmartSDR tho!
Steve, M0BPQ0 -
Different topic, but related to use the winkeyer.
https://community.flexradio.com/flexradio/topics/cw_sidetone?utm_source=notification&utm_medium=email&utm_campaign=new_comment&utm_content=reply_button&reply[id]=20245217#reply_20245217
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
