Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
Using 6400 on 11 meters band
I would like to know how can I TX on 11 meters band
- 70 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 89 SmartSDR for Mac
- 144 SmartSDR for iOS
- 150 SmartSDR CAT
- 70 DAX
- 279 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 558 Maestro
- 14 FlexControl
- 723 FLEX Series (Legacy) Radios
- 155 Power Genius Products
- 120 Power Genius XL Amplifier
- 12 Power Genius Utility
- 23 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 90 Remote Operation (SmartLink)
- 50 Contesting
- 131 Peripherals & Station Integration
- 63 Amateur Radio Interests
- 408 Third-Party Software
ECC/DEC/(11)03 --- CB QRP OK in Europe?
...in the frequency band 26.960 MHz to 27.410 MHz ... 12 Watts (measured as a peak envelope power) for SSB modulation...
Suggest you call Flex directly and ask them
No regardless of where you are in the world.
If you need 11M operation, 11M radios are very inexpensive.
I repeat once again: In the Flex Radio software version up to V2.28, it is possible to work on the 11 m band. In USA, have the laws changed, or for what reason can I not use Flex to transmit to 27 MHz with V3.0 as before?
There are many hams who deliberately do not switch to version higher than 2.2.8 due to the inability to work in the 11 meter range for transmission.
Why not open this opportunity for those who are not forbidden to work at these frequencies, because for this you do not need to invent anything additionally, but do it as it was already done before. I like the stability and functionality of Flex Radio, but I absolutely do not understand the policy of limiting the rights and freedoms that they introduced with the new software.
But what before version 2.2.8 did ARRL and the IARU allow work in the 11 meter range or did something change? ))) You can not answer.
The ARRL is not an official agency or authority. It has absolutely no power to set or enforce rules.
Many hams seem to think that the ARRL governs ham radio. They do not. They are a private organization that promotes ham radio. That's all they are.
