Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
Change Mode using USB Cable
I am successfully using a USB cable to communicate with an Arduino-based mag loop controller. The cable passes transmit and frequency comands but will not change the mode to AM for tuning the antenna from the Arduino.
I presume that any remote tuner connected by USB would need an AM carrier. I have not had success with DDUtil and would prefer the 'direct' USB cable option. Has anyone been successful changing modes using the USB cable?
Thanks, Ron K2RAS
Thanks, Ron K2RAS
- 69 Community Topics
- 1.9K New Ideas
- 118 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 84 SmartSDR for Mac
- 143 SmartSDR for iOS
- 149 SmartSDR CAT
- 66 DAX
- 278 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 553 Maestro
- 14 FlexControl
- 721 FLEX Series (Legacy) Radios
- 149 Power Genius Products
- 117 Power Genius XL Amplifier
- 10 Power Genius Utility
- 22 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 88 Remote Operation (SmartLink)
- 50 Contesting
- 127 Peripherals & Station Integration
- 61 Amateur Radio Interests
- 403 Third-Party Software
The Flex USB cables output three types of data CAT (bi-directional), BCD, and Bit. All you should need to do is press the tune button in SmartSDR to cause the tuner to do its job. The tuner would need to be set to tune automatically. Tune is simply a carrier (CW) similar to an unmodulated AM carrier. If I've missed the point then perhaps you could provide specifics on the tuner you are using so that I can research it on the web.
Mack
W4AX
The Arduino tuner is programmed to initiate a tune cycle which sets the mode to AM, drops the power level, tunes the radio, and then resets the radio to its initial settings. This works fine with an ICOM 7300 radio, so either the commands are incorrect for the Flex (it is using Kenwood TS-2000 commands), or the USB interface on the Flex does not support the mode switch and power level commands.
As mentioned, the direct USB cable with the FTDI interface does properly initiate a tune and pass frequency data from the Flex. If I could get the other functions to work I would not need to use DDUtil (which I can not get to work) on the current SmartSDR release.
I appreciate any advice.
Ron/K2RAS
Sorry for the tardy reply but I've been thinking about your question. The USB ports on the back of the computer, as far as I know, do allow for input of CAT commands.
Perhaps a better application would be to have your tuner assert a Tune command via normal CAT running on a PC. CAT on the Flex is handled using software verses hardware to minimize the spaghetti cables that are behind a typical radio.
Mack
W4AX
I am not sure if there is a CAT command to send TUNE.
Much appreciated, this is the final challenge getting the loop controller to function with the Flex.
Ron / K2RAS
That CAT user guide is at https://www.flexradio.com/downloads/smartsdr-cat-user-guide-pdf/
It looks like you can set the TX mode, power and then put the radio into TX Have a look and see if you can find a solution. You can then return it to the previous state.
Thanks, Ron / K2RAS
17:46:03 (RX): PC;
17:46:03 (TX): PC000;
17:46:03 (RX): MD;
17:46:03 (TX): MD2;
17:46:03 (RX): MD5;
17:46:03 (TX): ?;
17:46:03 (RX): PC010;
17:46:03 (RX): TX0;
17:46:03 (TX): TX0;
17:46:06 (RX): RX;
17:46:06 (TX): RX0;
17:46:06 (RX): MD2;
17:46:06 (TX): ?;
17:46:07 (RX): PC000;
Thanks, Ron
Ron
19:12:30 (TX): IF000140700001000+0000000000020000000;
19:12:31 (RX): PC;
19:12:31 (TX): PC000;
19:12:31 (RX): MD;
19:12:31 (TX): MD2;
19:12:31 (RX): ZZMD5;
19:12:31 (TX): ?;
19:12:31 (RX): PC010;
19:12:31 (RX): TX;
19:12:31 (TX): TX0;
19:12:34 (RX): RX;
19:12:34 (TX): RX0;
19:12:34 (RX): ZZMD2;
19:12:34 (TX): ?;
19:12:35 (RX): PC000;
19:12:35 (RX): IF;
19:12:35 (TX): IF000140700001000+0000000000020000000;
Thanks, Ron
Ron
Thanks, Ron
Ron
And instead of MD9 for DIGIU try ZZMD07;
At this point, I would ask that you summarize your findings and open a support case so we can trace it correctly. This way it will get engineering visibility.
Thanks for all the help that others suggested.
Ron / K2RAS
Is the vox and dax not working together going to be fixed before v3.0. ? I hope so I am a vox person.
