FlexLogger Emerges
Mark_WS7M
Member ✭✭✭
Hi All,
A while back I showed my quickly spun logging program and found a fair number of you had some interest. So... being the idiot I am I decided what I had was far from ready for others to use and I basically rewrote it from scratch.
The new program is currently called FlexLogger. It currently has a fair number of cool features and the list will continue to grow:
It is in a very early state right now and there are bound to be some issues but I am dedicated to fixing what I can find and making this a really good little logging program.
If you would like to give it a try the installer can be downloaded from here:
http://184.154.226.168/flinstallers/FlexLoggerSetup-0.0.7.0.exe
There are a few things you need to do once it is installed before it is ready to use:
At this point you can poke around and look at things. If you want to import your data from another logging program just export that data to an ADI file then use the log management tab to import the data into your FlexLogger database.
Once you have this version installed, future updates are handled by an in program updater that can download and update your copy to the latest version.
Operationally if you manually enter a call sign into the call field in the log, use the tab key to trigger lookups. The esc key will clear log entries.
Again, this is very early. there are some things that will change. But let me know what you think.
- Interfaces with your flex, provides a number of in logger flex controls
- Fast database logging
- Integrated spots with user configurable spot sources
- Spots interact with your logger and any online looks you have enabled
- Monitoring and automatic logging of WSJT-X QSOs
- SPE serial amp monitoring and control
- Scripting, assignment of scripts to quick buttons
- Call lookup via QRZ or HamQTH
- Qso posting to HRDLOG.NET (club log coming)
- CWX macros including speed changes and send of variables
- Click the gear icon, top left, to enter program configuration. In here enter any online lookup services you use like QRZ or HamQTH. There are also some preferences and if you have an SPE and wish to control it over RS-232 you can enable that here as well.
- Next icon over you must create a station. The next icon over allows you to define and save a station definition. This includes things like call, location, grid, etc.
- Next icon over will let you define an operator. You can have multiple operators if you are lucky to have multiple hams in the house.
- Next icon over will let you create a radio definition. Currently Smartlink connect is not working but you can define details or IP addresses for where your radio is.
- Next icon over will let you create a database. FlexLogger will remember and use the last database you open but you can have as many databases as you wish. For example if you are working a contest you might start a new contest only database. Totally up to you.
17
Congrats, Mark!0
Mark,
It looks very good. I hope to get by radio back from service very soon and really would like to try it.
One thing for the wishlist - do you have a Map in the Menus?
I am using LogHX that gives several options for the Maps, provide visual path to the station that I click on cluster, Lat, Lon, Dist and Azimuth.
Here is an example:
Does your Log have an option to see the active Slice?
Sergey, KN7K1 -
Mark
Interesting!
Will there be a color theming feature for those of us that find MultiPSK style nauseating?
Just kidding, sorta, or maybe not.For real-time discussions
User-created documentation.
Volunteer!!73, Jay - NO5J
I have the Flexlogger software and what Mark has achieved in the last few weeks is amazing.
I am sure that this is going to be a heavyweight amongst logging programs.
Tim2 -
Loving this new program.
I am not familiar with scripts though . . . Is there an easier way to program a "macro" button to start a program.
Mark, Congratulations - Impressive !
As an enthusiastic EME operator . . . do you see a chance to implement an interface for WSJT (not only WSJT-X) ? That would make a difference for me.
Hi Sergey,
No map yet. But I have something like that on the list.
Currently, in this early form, there are slice panels for two slices, A and B. Once I feel the slice panels work well and require minimal changes I will replicate them for slices out to H (6700 owners). The slice panels take a little work to hook up so I don't want to do all 8 then find I have to make big changes to all 8.
The slice panels show and allow you to control virtually all parameters about a slice even the filter:
All of these controls are active including the filter box at the bottom. You can quickly drag that lighter colored box around to change your filter center or edges.
The labels "Slice A" being yellow with a black background indicates this is the active slice much like the Yellow line on the SSDR. The TX label, white over red indicates this is the TX slice.
Jay,
Right click on any panel to change the background color. That color is remembered. You can quickly set them all to standard background. Obviously, there are some combinations that are sort of ****: Black background gives you a window where you can see nothing. LOL I don't have any foreground color set ability because there are many Windows controls that simply do not allow the color to be set. They kind of ignore it.1 -
Thanks Tim! Get out in the cold and fix your antenna!!!0
Steve,
Right now no... But... This gives me an idea...
It would not take much to add a new menu item "Start program..." which brought up a file open dialog. You would navigate to the program then select it. Once selected the code could generate a script automatically for you that starts that program.
I'll put it on the list!1 -
That would be AWESOME
Wolf,
Can you email me some specifics about what interfacing with WSJT would make it useful? I have never run WSJT for EME or anything similar.
I will download WSJT and take a look at it but please send me an email on what specifically would make it work well. ws7m@arrl.net
Mark0 -
Mark
Great, I won't need the bucket next to the shack desk then, so I can safely dig in and try out FlexLogger with no worries about nasty spills.I just thought it might be easier to ask for control of certain aspects of the GUI, sooner/now, as opposed to later, when changes might mean breaking important functionality, sounds like you knew that might come up.
I love this, Software development in Real Time directly with the users!
Great job Mark!
I just imported my log and love what you have done here. Looking forward to using it more. Thank you for all your hard work.0
Mark: Congrats your doing a great job!
If you need more hosting I'd be glad to post a download on my site or place a link to the file, just let me know.0 -
Mark,
There are many of us that are into IOTA awards from the RSGB.
Can you include the grid of the stationed worked and the relevance of that grid related to the island:
Keeping it somewhere near the country or State columns.
Ham Radio Deluxe does an excellent job in that area.
73, from IOTA: NA-138 Amelia (island, FL)
wow is this easy except...I exported my HRD log as an ADI. Imported it to Flexlog, import prompt said it imported all my log, but, I can't get the imported log to display on the Flexlog screen.0
Hi Mark!
Thank you for the your great job.
basically, everything works fine,
but the Lat, Lot, Distance, Bearing windows are remain empty.
Did I do something wrong ...
Now if it only could run on a Mac.0
thanks John!0
Thanks Tom!0
Hi Ernest,
I have plans to add award tracking. This should not be difficult. I will need to understand it a little better.
Would you be willing to email me a description/overview of what it does and I will in the meantime take a closer look at HRD.
Mark ws7m@arrl.net0 -
Hi Craig
Be glad to help you out.
First, in 0.0.7.0 the import changed in such a way that when you run the import it brings the ADI data in into a temporary memory based file. The plan was for you to visually review it then commit it.
I notice that the window in 0.0.7.0 is a little messed up and perhaps it was not clear. But did you press the button to "Commit to database"?
If not, please try your import again but finish by pressing the commit button. I will push an update later tonight that fixes the screen draw issue.
Also on the main tab "Log & Control" there is a refresh button near the log. Try pressing that.
If you did press the commit button and refresh it still does not show up for you.
1) Send me your most recent few logs from C:WS7MAppsFlexLoggerLogs
2) Also send me your database.
3) Send me your ADI file you are importing from.
I will dig in and figure out what is going on!
mark - ws7m@arrl.net0 -
Hi Mike,
First, do you have your own lat/lon setup in your station definition:
Next for automatic look ups you have to enable QRZ or Ham QTH in program config. You need to put in your login and password:
Assuming you've done all that then we need to look into if the online request is simply timing out.
If you have everything filled out you should be able to type in a call sign and hit the tab key and the lookup should occur. If the lookup is successful you will get lat/lon and other station data on the callsign.
If you have data in the dialog and you want to lookup another station you must first hit Clear. The lookups will not overwrite existing data.
If you are not getting that then it could be a network issue.
I will being making a few bug fixes tonight and will push an update. In this next update I will add some logging and timing controls to the lookups and we will try to figure out what is going on.1 -
ya that would be nice!!!
Mark I was getting ready to suggest that might be the problem, I imported almost 3000 Q's with no issues let it sort out its thing then, when done press commit to database and all done.0
Rick, I bet it is. The form is messed up in V0.0.7.0 and I suspect it was that the commit was not showing.
I'm gonna push an update tonight that fixes the screen.0 -
No "commit to database" button on my menu. Will wait for your update and try again.0
Hi Craig,
Update is done. Run flex logger, under help menu, check for updates.
Let me know if you can see the commit button after that!
Mark0
- 315 Community Topics
- 574 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 855 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
