FLEX 6300 6500 6700 fans
K2CB Eric Dobrowansky
I’ve had a number of emails lately inquiring as to fan availability. If we can get enough takers, I’ll order another 100 fans. Maybe if everyone committed to a minimum of 4 each, we could make it happen quickly. If you have interest, contact me directly at k2cb at comcast dot net. Give me an idea of how many you want. Min of two, preferably four. Hopefully I can get the mfg to honor the same pricing as last time. I’ll report back as to whether or not we have enough participants to make another group buy work. Eric K2CB
Are these case fans or CPU fans?1
Hello Eric- I will take 4; I hope the QA will be a little better as one of the fans from the last batch lasted only 3 months. Thanks; Bill0
CPU. Case fans are readily available from Mouser and DigiKey.0
I would hope so. Unfortunately there really isn’t much choice as to suitable direct replacements.0
I take 4 fans
Guys, becareful changing these, they are held on by industrial glue , that may make the fans difficult to remove and can damage the chip they are attached to, which can be very costly to replace. Just a word to the wise. Dudley WA5QPZ0
Dudley- the fan comes off the heat sink with removal of 4 screws. So removal of the heat sink is unnecessary.1
I will take 4 also.0
Dudley,
These are exact fit replacements. They come supplied with the connector pre-attached, and the same heat sink.
However, almost everyone has been opting to simply unscrew the fan from the new fan/heat sink assembly, and simply swap the fan itself onto the pre-existing heat sink.
Most have reported the process to be quite simple. Swapping the heat sink, well that is another story. But for those not wanting to send their radio in, this is a quick, simple, and cost effective way of getting their radio back in service.
Eric
K2CB0 -
Guys, please be sure to email your requests direct, so I can be sure to add you to the list. It will also allow me to follow up once we are ready to proceed. Thank you!2
Dudley, I made some notes on my web page about both of the types of fans used in the 6300, 6500, & 6700. There are pics, connector options, error msgs, etc. http://nn4zz.com/FLEX6700.htm#FANs_ Regards Al / NN4ZZ1
Hello Eric K2CB,
What is your direct email address, I need to order 4 - FPGA / CPU 50MM fans I have the other fan's.
Please let me know at
wx7y at arrl.net0 -
I would be interested in fans also and 4. Units if they become available.0
I will take 4 fans whenever you get them
W7ZAC (QRZ OK)0 -
How much $$ were the fans last time?
Tnx, Jim K6JR0 -
k2cb at comcast dot net0
I will take 6 fans please I have a 6300 and a 67000
I think $200
I must have missed a message or two but why do you all order fans? Is there an issue with the fans used in the radios and does Flex not honor warranty (assuming one still has warranty)? would it not mess up the warranty if one opens the radio themselves? 73 Andy KU7T0
Dave ...Per Eric's request above.. Send the fan requests direct to him at
I second Andy's question. Do these fans reduce the ridiculously loud fan noise on the 6300? My office is totally silent until the darn Flex gets turned on. The only thing I don't like about Flex!2
Andy - the warranty would indeed cover the fans, and Flex will replace them should they fail within the warranty period.
People are ordering these fans as they either have had, or suspect they may have, a fan fail outside the warranty.
Both of mine have failed after about 2.5 years.
The advantage of these particular fans, which Eric is hopefully going to be able to source, is that they are the same as the originals and so you can unscrew the fan itself from the heat-sink and replace that part only. The heat-sink is glued onto the component and is difficult to remove without danger of damage.
Hope that helps.
Steve
The replacement fans are the same fans that the radio comes with, how can they cool the radio without fans?0
I dunno, maybe use fans like the three in my computer that are totally silent? This is not hard. My previous HF rigs made zero noise on receive. I realize these rigs are doing more, but it is still annoying.
Maybe you're talking about a different issue? My 6300 was virtually silent until the fans started to fail. Had they not failed, I would certainly not have seen them as a problem.
Paul,
I share your pain...the fans in my 6300 have always been noisy.
Bill,
Who said anything about running the radio without any fans?
Just wait until you hear the fans in the new amplifier. It sounds like a hovercraft getting ready to launch.0
If your not running an M model, consider placing your radio under a desk or some place similar to reduce the noise at your operating position, after all they are considered radio servers and they do not need to be in front of you to operate. I started operating remote in my house, all radio gear is in a back room while I operate in the den.
I did that but he does not reply!!0
Everyone who replied directly is on the list. I apologize for not replying to everyone individually yet. I have a ton of email to catch up on after being out of town for the holiday.
We have met the minimum requirement. I will be sending everyone an email with instructions later this week, once I have confirmation from the manufacturer.
Eric
K2CB1
- 252 Community Topics
- 490 The Flea Market
- 7.4K Software
- 332 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 781 Maestro
- 42 FlexControl
- 733 Genius Products
- 254 Tuner Genius XL
- 86 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 586 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
