Succesful 6000 Power On/Standby Control on the Lan Solution with WeMo
James Nelson
Applying the open collector voltage as Steve N5AC advised then a small relay means an iOS or Android app with a Belkin "WeMo" IP switch & plug pack allows me full control to put my 6000 into "Standby or On" so the gps reference keeps running. Great solution, happy camper. Small caveat until the next release is power off twice for the command to activate the stanby state, no big deal.
2
Cool! Do you use the WeMo to control a small power supply that runs the relay? Any chance for a diagram of your very nice solution?1
Hi Geoge, Not being the sharpest tool in the shed I have to find a simple way to explain as my schematic drawing skills are non extexistent. The most basic explanation is I did this; 1. Ran a + - line to the RCA live pin on the remote plug socket with a 2.2k resistor in series from the 6000 power supply rear as it is always on and I desired a standby mode for the GPS 10mghz out to my Flex1500 on WSPR at all times. 2. Found a used 12v mini relay and used the normally open contacts and connected them to the RCA directly AFTER the 2.2k resistor. 3. Ran another + - from the relay coil to an old 12v plug pack and plugged it into the Belkin WeMo with an old 12v dc plug pack. 4. Downloaded to andoid (or iPhone app) and it works. Note : To place into standby you need to turn on and off twice as I believe the next release will fix the switch "double push" bug... so I saw post in the community. Hope this helps but it does work and my android is with everywhere so solution for me solved. Steve N5AC made me see the light with the open collector remote port0
We just need a photo of the app that says; FAN LAMP CURLING IRON FLEX-6000 ;-)3
OK.... Now the XYL has spotted your reply in my email its off to our local version of Home Depot for more switches. Now you have started a remote craze here thats going to dent my already bruised credit cards. ..... LOL :-)0
James is now "leader of the pack" -- just hooked my WeMo up and am enjoying the ability to switch my radio on and off remotely. Geo0
Anyone capable of sharing a schematic diagram?0
Looks like a marketing opportunity to me ;-)0
You know the next question will be for a BOM with part numbers, right? ;-)0
For those who are interested in the Wemo solution, Amazon is having a 1 day sale on these. This is the best price they have been since Black Friday. http://www.amazon.com/gp/goldbox/ref=pe_36900_112206160_dotd_h_t0
TNX - Just ordered one0
TNX - I just ordered two. One to cycle power my FLEX-6700 remotely as James and George have led the way. The second WeMo will cycle power off and on to an MFJ-998RT remote antenna tuner which sometimes requires a power cycle when moving from a lower band to a higher band. This happens because the tuning solution from the previous band results in a very high SWR on the new band. (The power injector is mounted after the remote antenna switch that allows the antenna tuned with the MFJ-998RT to be used in two different locations. Therefore, the WeMo will cycle power from either operating location, or during remote operation of the FLEX-6700.)0
Thanks, Matt! Ordered another to experiment with, plus a wall switch to remotely turn on the lights in my teenager's room without violating the sanctity of her nest...0
Think we better check to see if Belkin is listed on the "New York Stock Exchange", I am sure there will be no insider trading issues. Keep it under wraps gentlemen.0
I recently added a remote (feedpoint mounted) antenna tuner to my system. The MFJ 998RT does a great job of matching my antenna, but does occasionally need to be reset by having power disconnected briefly. When I'm in the shack, it's easy to flip a switch, but with my remote operations, I usually have to call my tech support rep (teenage daughter) to reset.
The WeMo project worked great for rig control, but now another set of contact closures would sure help remotely reset the tuner. Enter the Global Cache IP2CC. Three closures controlled by an ethernet controlled device. Control from anywhere with Roomie Remote app or similar (open the necessary ports on your router).
As the shack has evolved, I've eliminated wall warts and added a deep cycle 12 volt battery to my station bus. The WeMo solution became a little clunky as a result. Although, as you can read above, they work fine if your architecture is appropriate.
Now my Flex remote on and tuner reset are accessible anywhere. Looking for a use for the third relay. I wonder if I could make it a CW key?
The IP2CC is available from a variety of places on line.
Remote operation is a blast.
Geo0 -
This is great but I was wondering if the Flex 6000 will ever be able to be turned on/off without the need to use any external devices? As an example, I have both the Elecraft KPA500 and KAT500 both of which can be turned on and off via software control. No other devices are required.
Norm - W7CK0 -
Hi Norm, if the link between the Flex (a radio server) and SSDR (a client) is the problem, it could lead to a hang not recoverable by software. Thus, the hard closure. While a software "on/off" might be good for some circumstances, I like the ability to remotely reboot the server directly. I'm attaching a shot of the interface for those interested.0
HI George
can you explain how the Flex is connected to the Global cache unit. if you explained that I am missing it. I assume the Remote RCA jack on the back of the flex connects to one of the 3 ports? if so is it just 2 wires direct or some other electronics involved?
thanks
K4JKB
I have been using this wifi enabled switch. It is cheaper than the WeMo and no need to create a relay box. I bought directly from the manufacturer and received it in a week. Software is not WeMo quality, but support is very good. http://en.usr.cn/1-Channel-Output-WiFi-Remote-Control-Relay-dc-power.html I also use a WeMo to control the power supply ON/OFF. This way I can reset each device independently.0
Just two wires - contact closure to the RCA connector. Remote on needs to be enabled in the Flex setup.0
Top of the list of course....
For those that want to see what's inside, just saw this:
http://edn.com/design/consumer/4440797/Teardown--WeMo-Switch-is-highly-integrated
For my remote project i have opted for this one http://www.digital-loggers.com/220.html
8 socket so have room for Radio ,Linear , Astron PSU and so on ,simple scripting permit to sequence power up or power down and if VPN routeur crash build in "watch dog" power cycle it
so it usefully when radio was mountain top 200 mile away
have initially planed to solder a opto-coupleur on one of the relay coil for control the remote on of radio ,but idea on that tread may better and keep the warenty of the power bar ..
p.s. it have more expensive unit that also monitor power usage may useful when need to share electric invoice
Marc VE2OLM0 -
I am planning to use this unit. It is very similar to the WiMo but about 1/3 the cost.
I bought three of them at Christmas from Amazon.
I have been playing with them to get used to the software by turning lights on and off from my office via my iPhone both via WiFI and Cellular. It works well.
http://www.amazon.com/gp/product/B00IWHDAKA?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s...
It is only US$21.99 and has applications for iPhone/iPad and Android phones.
I will be using a 117VAC relay connected to the switched AC of the Ankuoo Neo and using two N.O. contacts from the relay to switch the remote port on and off. I see no reason, other than fear of short circuits, to use a wall wart or other power supply to activate a 12 volt relay when a 117 VAC will do the trick. Unfortunately the relays I ordered won't arrive for several weeks.
I will use another unit to control the 12 PS feeding the Flex and other rigs in case I need to do a complete cold reboot, and will use a third unit to power cycle the computer if necessary.
One of them may do back-up duty as a vacation lamp-minder. I won't be leaving the station wired for remote ops all the time because of the tendency for Indiana to have pop-up severe thunderstorms with lightning for over half the year. (There ARE some advantages to living where it gets colder in the winter!)
Ken - NM9P
The 12V power supply for my Flex 6500 has always been on a mains switch controlled by my home security system. I hesitated on installing yet another device to control the remote input on the Flex.
However, I found out that if you just leave the input grounded all the time (using a shorted RCA plug) the Flex turns on as soon as 12V power is switched on (locally or remotely).
To turn it off the 12V power supply can be turned off (again locally or remotely) resulting in an unexpected power loss to the Flex, but a proper shutdown it is still possible using the front power button.0 -
... a soft button in SSDR called "Power Off"
It will give me a better feeling if i like to stop remote working and i can shutdown my Flex6 on normal way (like press Power button on my F6 - then switch off the PSU
Then i can switch off also any MEMO to switch off the PSU.
If i like to restart remote i start MEMO switch for PSU and then F6 came up
Bad idea?
Chris1 -
Good idea. Even when not working remotely it can be handy to be able to turn off the Flex using SmartSDR.0
And UL, CSA, FCC approvals and certification labels, ISO 9001 support, along will MIL-SPEC documentation and SCIF compliance. Final price: $5,999 in quantities of 1000 or more.
I find a simple ground at the "remote on" RCA is not turning the radio on. "Remote" is blue in the radio set up. The radio itself is off. Ground is supplied by a relay. The V2 hardware manual notes a max 3.3v dc. Should I be reading this that I should be pulling a +3v line to ground to make the remote on work?
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
