Will the Maestro need to be on the same lan as the radio to upgrade to 2.0?
Jeffrey Kerber, N3VE
I leave my Maestro at my vacation home and want to know if it will have to be on the same lan as the radio to upgrade to 2.0. I use softether vpn and R PI to connect for operating now but have always brought the Maestro home to perform any software/firmware update. I just plug it into the same switch that my 6700 is plugged into. Will I be able to upgrade the Maestro from the remote location after I upgrade the 6700 or will I have to bring it home?
Jeff N3VE
Hi Jeff,
To upgrade the software it needs to be on the same LAN. Upgrades can't be done via SmartLink (yet).
You will also need to be physically at the radio to add the radio to SmartLink. It will require a physical button push (PTT) to get the radio paired.
Ria
Jeff,
You can update the Maestro separately from another location. You just select the new software version on the Maestro.
However, you MUST be in front of the radio to press the PTT on the mic or back panel in order to register the radio. This prevents someone from "stealing" control of your radio without your knowledge. This is a ONE TIME event when you first register the radio and you'll never have to do it again unless you change your login information.
Mack
W4AX
Alpha Team2 -
Ria and Mack have described the SmartLink pairing procedure. But in general, any SmartSDR client program can be installed anywhere, with or without the radio in the LAN. It has to be this way so that a remote client can run whatever version of the software it needs to run to access a radio.
The software license is installed in the radio and is associated with the radio, not the clients. If your radio has Version 2 licensed to it, then it can be connected to by any authorized version 2 client. Since the license is in the radio, not in the clients, you can install version 2 clients anywhere. If you attempt to connect to a version 1 radio with a version 2 client, that connection will be refused because the radio is not licensed to run V 2. I'm not sure what will happen if you try the reverse. It may be refused because of software incompatibility. But, you can install multiple versions of the client software on any system, so you can have a V1 client for one radio and a V2 client for another.
When Maestro goes out on the net to look for versions of software to run, it hasn't looked for a radio yet. You could have the latest V1 and V2 codes installed in Maestro then pick the appropriate version for the radio you intend to operate. The V1 radio would need to be in the same LAN (or connected via VPN), but the V2 radio could be anywhere connected via SmartLink.
Dave makes a very important point. Let's not confuse the SmartLink radio pairing procedure with Installing SmartSDR v2.0; they are separate procedures.
Let me clarify and reiterate a few points made
This is very important. Always keep this in mind when discussing the 2.0 upgrade
Correct. You will have to upgrade the radio to 2.0 to proceed.
It will install the 1.x firmware on your radio because all radios are licensed for it and reboot. Then you can run the 1.x client with your radio.
Yes, my mistake for not being clear.
Client software is independent. SmartLink requires physical access.0 -
I am still not clear on this. I will be at the 6700 to upgrade and pair. After that is done I will go to the vacation home and want to operate the Maestro. Will that work? I will also have access to the shack PC via teamviewer. That is how I operate DDUtil and my amp. Thanks, Jeff0
Yes, it will work seamlessly while remote. Mack W4AX0
Thanks Mack and others. I don't know why I thought the Maestro had to be updated in the shack with the radio. Jeff0
The maestro gets its software from the flex mothership. So it can be upgraded anywhere.0
Ria, different question, if 2.0 comes out while I am at the remote location can I upgrade the 6700 via teamviewer? Not sure I would want to try, I have had an upgrade where I had to hard reset the radio. Seems this would be possible though.0
NO You have to physically hit PTT to register the radio to your SmartLink account Solution: put a remote relay across the PTT port so you can register the radio remotely I]I am going to do that formy radio so I can register it with new versions of alpha code when I'm away0
Actually the answer is yes. You can upgrade to 2.0 remotely. But you can't register the radio in smartlink until you can physically push the PTT. So all other functions of 2.0 will work except smartlink.0
Howard - please read the thread. This is not about SmartLink Registration, it is about software updates. You're confusing the issue.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 720 Genius Products
- 387 Power Genius XL Amplifier
- 249 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
