Win 10 Creators version update ...
Just got the creators update... only issue was DAX driver crashing now
will uninstall and re-install smartSDR ...0 -
Try reading this and uninstall, running the cleaner then reinstall. It was one of the steps I used and worked Mike N9dfd https://helpdesk.flexradio.com/hc/en-us/articles/115000504463-Removing-In-Use-Com-Ports-for-Available-Com-Ports?_ga=2.63773865.705304606.1497710621-145709167.14953953570
yes, had to do full uninstall, then re-install, then only the VSP driver would complain, after re-installing that again got it running again. Then had to mess with windows soundcard channels a bit. Now all back ok ...0
Good to hear0
If you want to install the update now, select Start > Settings > Update & Security > Windows Update, and then select Check for updates. If updates are available, install them.
Brother Printer Keeps going offline
After update the system into windows 10 my Canon PIXMA TS307 Inkjet Printer is not able to recognize the system. I consulted with canon printer repair there I got to know that printer is absolutely fine. Then what is the exact issue and how it will be resolved?
Olivia, you are asking about a printer issue on a Ham Radio forum. I would recommend you go back to Canon. This has nothing to do with Flex Radio.0
I had my HP Network printer stop working with W10. An update nuked the driver, and the printer is now unsupported. Worked fine until Microsoft decided to abandon it.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
