Win 10 Creators version update ...
2»
  • Wim
    Wim Member ✭✭
    edited October 2019
    Just got the creators update... only issue was DAX driver crashing now
    will uninstall and re-install smartSDR ...
  • Mike NN9DD
    Mike NN9DD Member ✭✭
    edited June 2017
    Try reading this and uninstall, running the cleaner then reinstall. It was one of the steps I used and worked Mike N9dfd https://helpdesk.flexradio.com/hc/en-us/articles/115000504463-Removing-In-Use-Com-Ports-for-Available-Com-Ports?_ga=2.63773865.705304606.1497710621-145709167.1495395357
  • Wim
    Wim Member ✭✭
    edited June 2017
    yes, had to do full uninstall, then re-install, then only the VSP driver would complain, after re-installing that again got it running again. Then had to mess with windows soundcard channels a bit. Now all back ok ...
  • Mike NN9DD
    edited June 2017
    Good to hear
  • Berry Johnson
    Berry Johnson Member
    edited October 2018
    If you want to install the update now, select Start  > Settings  > Update & Security  > Windows Update, and then select Check for updates. If updates are available, install them.
    Brother Printer Keeps going offline
  • Olivia Watson
    Olivia Watson Member
    edited November 2018
    After update the system into windows 10 my Canon PIXMA TS307 Inkjet Printer is not able to recognize the system. I consulted with canon printer repair there I got to know that printer is absolutely fine. Then what is the exact issue and how it will be resolved?
    edited April 2019
    Olivia, you are asking about a printer issue on a Ham Radio forum.  I would recommend you go back to Canon.   This has nothing to do with Flex Radio.
  • Michael Coslo
    Michael Coslo Member ✭✭
    I had my HP Network printer stop working with W10. An update nuked the driver, and the printer is now unsupported. Worked fine until Microsoft decided to abandon it.
