MFJ-1026 and Flex-6300 interfacing
Alberto Girard - VE2ELW
How would you make connections between a Flex-6300 and an MFJ-1026? Is there a way to bypass completely the connection to the ANT 1 and use some sort of auxiliary recieve input, like with the Elekraft K3? Then I would not need to bother about connecting the PTT, nor swr, nor high power (because I have an AL-80B linear).
Alberto Girard, VE2ELW
Try the XVTR port.0
Salvador is correct. On the 6300 the Transverter port doubles as an alternate receive port.
Ken - NM9P0 -
I use LoopA on my 6500 but not very happy with the MFJ-1026. It takes to long to setup for the return of reduction of noise. It will reduce noise and can be effective and if I had something on a frequency I used often I would find a way to deploy it.0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
