MFJ-1026 and Flex-6300 interfacing
How would you make connections between a Flex-6300 and an MFJ-1026? Is there a way to bypass completely the connection to the ANT 1 and use some sort of auxiliary recieve input, like with the Elekraft K3? Then I would not need to bother about connecting the PTT, nor swr, nor high power (because I have an AL-80B linear).
Alberto Girard, VE2ELW
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited March 2018
    Try the XVTR port.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    Salvador is correct.  On the 6300 the Transverter port doubles as an alternate receive port.
    Ken - NM9P
  • Dan -- KC4GO
    Dan -- KC4GO Member ✭✭
    edited November 2016
    I use LoopA on my 6500 but not very happy with the MFJ-1026. It takes to long to setup for the return of reduction of noise. It will reduce noise and can be effective and if I had something on a frequency I used often I would find a way to deploy it.
