N1MM+ setup with SmartSDR
Les Brown
I'm trying to set up N1MM+ with SmartSDR for a Flex 6500. I must be missing something obvious. In SmartCAT it says to use COM port 5 for 3rd party software, so I selected that in the N1MM+ port configuration. I can see the frequency change in the N1MM+ header when I scroll the frequency with my FlexControl. However, there is a message at the bottom of the N1MM+ window "No CW port is set in Config". How do I configure this to use the Flex 6500 built-in keyer? I'm not using a WinKeyer.
Les
SmartSDR doesn't have CW-controlled comm ports yet (like it does in PowerSdR for the legacy radios). I use a WinKey keyer from K1EL to interface between N1MM and the radio.
730 -
Or do what I did - search on here for the kenwood cat control commands required to utilise the ssdr Cwx built in keyer - someone on here posted their n1mm cw f keys template and I just copied and pasted into n1mmplus cw function keys file and then saved it as "flex cw keys template" file in n1mmplus - I then just edit that basic file to suit each type of Hf contest I do and sometimes save it as a file for that contest with a relevant file eg for rsgb commonwealth contest I would edit the f1 key command to include "cq beru" and the same for cw ops qso parties or cw open contest I edited the file to say "cq cwopen" . I have my paddle plugged into my 6500 radio and can send fills on the paddle or. I can use the f1 key etc to send cq via the cat command which triggers the ssdr Cwx built in keyer, and either have the cw speed the same or untick the synch option if you want a different sped for the paddle sending. It works well and I have not therefore wired up my win key microham keyer for the rear of my 6500 or 6300 and just use it with my legacy Icom ic7400 radio on 2m contests. 73 Steve gw0gei / gw6j2
Les,
You could try my step-by-step "How-Tos":
HOW-TO: Setup FLEX-6X00 with N1MM / CW Skimmer for multiple slice contest operating
How to: Setup N1MM+ for keying the Flex 6X00 via CWX
VY73
Tom
DK1EY0 -
Tom's Tutorial is good.
IF you want to do it without 3rd party interfaces such as DDUtil or Commander, you can simply use CAT to open up multiple Dedicated Virtual Ports and one or two PTT Ports. (I actually have three)
Then you have two options:
1) Use one port for the rig to software communication, and another port for the PTT.
Or
2) Tell N1MM+ to use CAT commands to control PTT.
Either way works.
But remember, you can only use one software program with each individual Dedicated port at the same time. So if you have a Logger, RTTY Program, WSJT program, Voice Keyer, etc, they cannot use the same port at the same time. You need to provide separate ports, or you must close any other programs that use the same port.
Correct, Neal. I wish they would port the CW Key over to a Virtual Serial port line like in PSDR. It would be a great addition, although I agree that CAT & serial port access is quickly becoming obsolete technology. . I have learned how to key CW from N1MM+ using the CWX memories when doing major contesting. But I cannot send CW from any of my N3FJP programs because they use a serial CW Keyer interface. ACLog is still my favorite day-to-day logger, because I have been using it for about 12 years. I would like to use it when casually DXing. I don't want to pay for WinKeyer when I already have a $4400 rig that has an excellent built-in keyer.
What if you create a PTT port in SmartCat using the DTR line and then tell N1MM to use that port for CW. For some reason I think I tried that when I had my 6700 and it worked OK....I think....it was a while ago.0
If you do that, it just keys the PTT as CW, which doesn't help much. I tried it, too! When I tried it, I heard it keying the CW and said, "Hey! It works.....oh...no it doesn't! Rats." ha ha!0
Has this issue been resolved or is it still not possible to do CW keying from N1MM+?0
That was sooooo 7 months ago. :-)
SmartSDR v1.6 has many new features for integrating with N1MM specifically. SmartSDR CAT has a WinKeyer emulation mode1 -
Sweet! I'm shopping for a new radio and hope to make a decision by the time Dayton comes around. Looking a the 6500 and the Anan-100D. Will you be having any deals at Dayton?0
Stop by the booth at Dayton. We plan to have a station with N1MM integration. I'll do my best to ensure there is a set of paddles attached so you can give it a test drive.0
When I'm contesting I don't touch the paddles at all. N1MM+ does all the keying by pressing function keys. That's why I wanted to make sure it works. I'll look you up on Friday Tim. Thanks.0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 178 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
