Be able to delete any recorded audio, without turning off the radio
James Kennedy-WU5E
James Kennedy-WU5E Member ✭✭✭
edited June 2020 in New Ideas
It would nice to be able to delete any recorded Audio from the FLEX 6000 series without rebooting the radio.
0 votes
In Review · Last Updated
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited October 2015
    It must be recorded as an audio file. Maybe Flex would divulge that information. Or, maybe it's recorded in the radio, then that is a whole different story.
  • James Kennedy-WU5E
    edited June 2020
    it's in the radio , or I would have said reboot the computer,
    Jim
    wu5e
  • Jim Gilliam
    edited October 2015
    Perhaps a work-around would be to quickly double click the record button.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    I have noticed that each slice records its own audio. To erase them, double click the red record button in each slice.
  • Martin AA6E
    Martin AA6E Member ✭✭✭
    edited January 2020
    There are other recorder functions I'd like:
    • Indication of how much is recorded in the buffer (time, kB, etc)
    • Export / import of audio to PC (wav, mp3 formats?)
    • Simple editing controls (playback a selection, eg.)?
    There's a limit to what you can do in a tiny amount of screen real estate, without bringing up a new window.  Ability to export/import allows you to edit offline if you really care. FRS has said that's somewhere on their to-do list.
    It would be helpful to have a little block diagram that shows where in the "audio chain" the recording happens and where the playback is inserted  (relative to gain, eq, processor settings etc.).  Is the recorded signal, except for gain, the same as the MON output?
  • Jim Gilliam
    edited October 2015
    There is a third party program HDSDR that allows one to make IQ recordings up to 192 kHz. bandwidth. It's fun to monitor a segment of bandwidth at a later time.
