SmartSDR v3.3.32 and the SmartSDR v3.3.32 Release Notes | SmartSDR v2.8.0 and the SmartSDR v2.8.0 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
FlexControl with v1.4.16
With v1.4.16 I have to start SmartSDR two times to get the FlexControl to work. I down grade to v1.4.11 and it works like it should. In v1.4.16 this only happens when I shutdown the computer and 6300 and power supply. If I leave the power supply and radio on the FlexControl works first time when I start the computer. Anyone else seeing this? The FC shows up in Device Manger every time. I double check it before I state SmartSDR for the second time.
Thanks for helping
Terry
K7NY
Terry
My Flexcontrol had its com port reassigned by windows, when I did the upgrade, once I corrected the assigment It worked, it didn't require a reboot or a reinstall of anything.
See if you port assignment still matches.
73, Jay NO5J0 -
I am seeing the same as you with the 6500. Sure Flex will get it figured out soon. 73s Jim K4JAF0
No problem here. BTW: I'm using Windows 8.1. What are you guys using that are having trouble with? Win 7?0
Win8.1 here but I solved it.0
My first guess would be that you have not turned off power management on the USB hubs inside the device manager. Go to your control panel and look for Device Manager. Then look for USB Controllers. Expand that and double click on each item that is called a hub. See if you are presented with a tab called Power Management. If so, uncheck each checkbox that you see!
730 -
I am using 8.1, the com port is not changing. Like I said it works perfect in 1.4.11.
I will check the power management also.
Terry
We are aware of this issue. It does not seem to be related to the FlexControl driver or Windows and its crazy interactions with all things USB. And it is intermittent which makes it hard to find root cause.
We believe it has something to do with how SmartSDR is detecting the presence of a FlexControl that is connected to your PC. We investigated it yesterday and will continue to look into it next week. At this point restarting SmartSDR or possibly disabling and re-enabling it in the Setup is how to mitigate the issue.1 -
Hi Neal,
I followed your advice and it seems to have fixed the problem. I have a Flex 6500 and my computer runs Windows 8.1.
Thanks for your help.
Tom
I tried that and it didn't help.
Terry
Just got around to updating SSDR yesterday (Sat).
I am running WIN7 Pro 64. Flex control is on com12.
I notice in CAT that com4 / 14 is gone. Windows control panel sees it but not CAT.
I add a comport13 / 23 in CAT, reassign it and it turns to 4/14.
The part that makes no sense is that at this point the flex knob starts working.
Devil if I know, glad you're on the job Tim.
Lemme know what you figure out.
Clay N9IO
Hi Neal,
The mystery deepens. When I booted up my system this afternoon I had no flex control. When I looked at the eight hub boxes I had unchecked, I found the first box was now checked. I unchecked the first box and my flex control is back.
Who is the mystery box checker? I bet Tim knows.
Tom
Tom, I have seen this happen, even on the computer I am building right now for a customer and I have no idea how these get reset.
Hi Neal, One last data point. I lost the Flex Control again, I looked at the eight hub boxes and they all were still unchecked.. Thus ends my career as a trouble shooter. I am really much better at drinking **** anyway. 73, Tom0
It must be a very intermittent problem. I had the same problem with the Flex Control not working on reboot of the computer and 6500 shut down... Attached it via DDUtil and all fine.. Went back to controlling it on SmartSDR and has worked just fine for 2 days now with reboots, etc..
So not sure myself what is happening, sure flex will get a grip on it..
73s Jim K4JAF
This sounds like a different problem. One where you have "ghosted" virtual com ports that are confusing Windows and any application that uses serial ports. Here is an article you can use to remove the ghosted com ports
https://helpdesk.flexradio.com/hc/en-us/articles/200883925-Removing-Hidden-or-Ghosted-Com-ports
Yup am seeing this as well in the current version.
If I disable and enable the flex control driver in the device manager MMC then it's detected by SSDR the moment the device becomes active again and becomes usable.
However from power on the Flex control is not seen in SSDR, if you open the FC applet in SSDR it shows that the flex control is not present even when it is working as expected.
However and of interest DDUtil cannot take control of the knob as it says the com port is in use by another program - which I assume is SSDR even though it cannot use the control nor see its presence it has still flagged the port for itself.
No amount of reboots helps only the disable and enable the driver in the hardware MMC.
73 Steve
The mystery box checker is Windows. It is the USB Selective Suspend feature.
Refer to this article: https://helpdesk.flexradio.com/hc/en-us/articles/204290929-How-to-Disable-Power-Management-for-USB-c...
I tried this and unchecking all the boxes but it still takes two times to get the FC to work. Maybe Windows 10 will work better. Everything else works great.
Terry
Unfortunately, I am getting the same problem with the Flex Control but the software update has cured one problem I was getting and that was losing the Network connection on a regular basis. 1.4.16 seems to have cured that problem.
73, Bill
I do not have Flex Control and it happens almost all the time, need to start twice
Add me to the list. Never had this problem before upgrade to last update to 1.4.16. When booting ssdr flex is not detected and i have to plug and unplug flexcontrol several times to get it to work. Again, this has not been a problem prior to 1.4.160
I too have this issue. Not critical but a nusience. Hope for a fix soon. Peter GM4WCE0
I have been playing around with the FC this morning, in my desktop I have DDutil V3 for my amp only nothing else is checked. If I start DDutil before SSDR the FC works first time every time.
I went to my laptop and connected the FC ( no DDutil installed ) and it works first time every time.
I looked in Cat on the desktop and under physical ports /or foreign virtual ports shows com2 and com45 (FC ), on my laptop I don't see any other ports except the virtual com ports on both lap or desk.
Terry
For only one time over a period of a year, Flex Control died. This happened a few weeks ago with 1.4.16
Turning of/on SSdr had no effect.
Unplugging the FC and replugging fixed it.
This incident happened just recently after I decided to download and play with ddutil for the very first time. The reason I downloaded it was simply to observe the termperature. So I fiddled with ddutil for a while then closed it and haven't used it since.
Windows 8.1 here...
Happened only one time and not since then.0 -
Happens every time to me. Switched back to 1.4.11
Windows 7 Pro 64
Mike W9OJ0 -
Yes yes!! this version does not pick up the flex control. took me 5 times to get it working. does not happen in prior versions at all.0
Here are two screenshots or error messages when trying to connect the Flex Control...0
This has happened to me several times now, after turning off SSDR and leaving the rig and computer powered up overnight. If I go I nto the setup/radio tab and turn the flex control off for a few seconds, then enable it again, it comes back to life.0
I just got my brand new FlexControl yesterday and it has never worked (with 1.4.16 or anything else for that matter). About to send it back for a refund when I read these posts. I'll wait a few more days I guess.0
Fred, I can bet that the Flexcontrol has been assigned a comm port address that is already in use, which is why it doesn't work. Have you looked at the Ports section of the Device Manager?0
- 18.7K All Categories
- 141 Community Topics
- 2K New Ideas
- 294 The Flea Market
- 6.3K Software
- 5.4K SmartSDR for Windows
- 95 SmartSDR for Maestro and M models
- 218 SmartSDR for Mac
- 188 SmartSDR for iOS
- 181 SmartSDR CAT
- 116 DAX
- 321 SmartSDR API
- 7.9K Radios and Accessories
- 6.4K FLEX-6000 Signature Series
- 636 Maestro
- 30 FlexControl
- 780 FLEX Series (Legacy) Radios
- 435 Genius Products
- 253 Power Genius XL Amplifier
- 158 Tuner Genius XL
- 24 Antenna Genius
- 124 Shack Infrastructure
- 79 Networking
- 216 Remote Operation (SmartLink)
- 94 Contesting
- 319 Peripherals & Station Integration
- 89 Amateur Radio Interests
- 602 Third-Party Software
