N1MM+ Running SO2V Mutes VFO A
EduardoCarvalho
During CQ WPX CW 2015 when running SO2V on my Flex-6300, with latest SSDR, when the TX focus is changed to VFO B, VFO A mutes the audio output. This prevented hearing stations responding to my CQ.
Reproduction steps:
1. Open two slice receivers on SSDR
2. Set N1MM+ to SO2V mode
3. Start calling CQ on VFO A (slice A)
4. Change N1MM+ screen focus to VFO B
5. Note that VFO A (slice A) continues to call CQ, but slice A is now muted. Issue happens every time focus is changed from VFO A to VFO B.
Reproduction steps:
Do you use SDR Bridge? If so, check that the "Mute all but active slice" checkbox in the Radio-Tab is unchecked.
This is, how I configured it: HOW-TO: Setup FLEX-6X00 with N1MM / CW Skimmer for multiple slice contest operating
VY73
Tom
DK1EY0 -
Tom, Thank you for the reply. I think that was my problem, since I was using SDR-Bridge. I will confirm this later. Eduardo - KC8R0
I was running my 6300 with N1MM Logger+ in SO2V during the contest. I do not run a Skimmer or SDR Bridge. I did not have the audio muting program that Eduardo wrote about. I do encounter a different problem.
I do use Flex Control. When I open the second slice's panadapter I can switch between panadapter A and B fron N1MMLogger+. I can transmit on the correct slice and hear both slices.
But, I can not change the frequency of the second slice. To do that, I have to click on the second slice. Then the Flex Control allows me to tune that second slice.
When I move back to slice A from the logger I see the same issue. Turning the Flex Control knob continues to change Slice B until I mouse over to slice A and click there.
Anyone else have this problem?
73... Bill K3WA
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
