N1MM+ Running SO2V Mutes VFO A
EduardoCarvalho
EduardoCarvalho Member ✭✭
edited July 2018 in SmartSDR for Windows
During CQ WPX CW 2015 when running SO2V on my Flex-6300, with latest SSDR, when the TX focus is changed to VFO B, VFO A mutes the audio output. This prevented  hearing stations responding to my CQ.
Reproduction steps:
1. Open two slice receivers on SSDR
2. Set N1MM+ to SO2V mode
3. Start calling CQ on VFO A (slice A)
4. Change N1MM+ screen focus to VFO B
5. Note that VFO A (slice A) continues to call CQ, but slice A is now muted. Issue happens every time focus is changed from VFO A to VFO B.
  • DK1EY
    DK1EY Member ✭✭
    edited December 2015
    Do you use SDR Bridge? If so, check that the "Mute all but active slice" checkbox in the Radio-Tab is unchecked.
    This is, how I configured it: HOW-TO: Setup FLEX-6X00 with N1MM / CW Skimmer for multiple slice contest operating
    VY73
    Tom
    DK1EY
  • EduardoCarvalho
    edited July 2018
    Tom, Thank you for the reply. I think that was my problem, since I was using SDR-Bridge. I will confirm this later. Eduardo - KC8R
  • Bill Axelrod
    Bill Axelrod Member
    edited June 2015
    I was running my 6300 with N1MM Logger+ in SO2V during the contest.  I do not run a Skimmer or SDR Bridge.  I did not have the audio muting program that Eduardo wrote about.  I do encounter a different problem.
    I do use Flex Control.  When I open the second slice's  panadapter I can switch between panadapter A and B fron N1MMLogger+.  I can transmit on the correct slice and hear both slices.
    But, I can not change the frequency of the second slice.  To do that, I have to click on the second slice.  Then the Flex Control allows me to tune that second slice.
    When I move back to slice A from the logger I see the same issue.  Turning the Flex Control knob continues to change Slice B until I mouse over to slice A and click there.
    Anyone else have this problem?
    73...   Bill K3WA
