Android App
javier,
This is the only and the latest I have posted.
https://www.dropbox.com/s/3vvwcf82xkper3w/app-debug.apk?dl=0
It will be a long time before I post any updates, as I am in the process of redoing it from scratch.
William
Oh, no way William, what are you doing it from scratch for, if you don't mind me asking?
Walt,
My program is one big activity with zero fragments. I want to to break it up into separate classes, each with a specific function. I also want to redesign the UI using fragments. Not really starting from scratch, as most of the code will get reused to some extent. But it has got way too convoluted, and want to start fresh with a new project.
My plan is to build out a tabbed layout using fragments, that I can build off of. Then take my existing code and break it up into smaller classes.
This way I can focus on a piece at a time, get it working the way I want, then move on to the next. Starting from a tabbed UI, will give me more real estate.
I want to utilize swipe instead of a knob for tuning..etc..etc..etc. I can still have a tab fragment that uses the knobs if I so desire. But I need to start fresh with a framework I can build off of.
William
That is very close to what I'm doing. so I guess now I'll have to up my game. While Maestro is interesting, it won't compare to what we will be running on the Nexus, full SSDR compatibility plus other features. You'll find working with fragments much easier.0
Walt,
Maybe you can help me with something. Just for fun I am making my own waterfall from the FFT data. I am at this point able to draw a single line on canvas at 0,0. This line is composed of pixels each with a color based on its dbm. The colors are a gradient range from black to white.
If I manually shift y+1 on each draw, I get a working waterfall that scrolls down.
Now my problem is, I want the most recent data to always be at 0,0 and the second most recent data to be 0,1 and so on.
I can not find a way shift the canvas down one pixel so that the new data does not draw over the existing line.
William
NM I figured it out. Starting to hate android..LOL
I had to to draw and translate to a offscreen canvas/Bitmap, then draw that bitmap in the surface.
William
You create the bitmap 1 pixel in the Y direction and n pixels in the x direction then scroll the view and then print it.
But you are making that off the SL_VITA_FFT_CLASS? You should use the SL_VITA_WATERFALL class. I am confused how you are creating that from the FFT data.
Walt,
Just playing around. Since I'm somewhat stuck on the vita waterfall class. I just for fun decided to make my own with the FFT data.
I just dump the fft data into an int array. I then drawPoint(n,0,paint); scroll the window, repeat!
As for the paint color, I use a simple gradient based off value n.
William
to be exact, although this is hacked together it works, so it was a good experiment.
canvas = Panholder.lockCanvas();
int w = canvas.getWidth();
int h = canvas.getHeight();
bitmapoff = Bitmap.createBitmap((int) w, (int) h,
Bitmap.Config.ARGB_8888);
canvasoff = new Canvas(bitmapoff);
canvasoff.setBitmap(bitmapoff);
scale = h/200;
float xInc = (float) w / (fftint.length - 1);
paint.setColor(Color.BLUE);
if (tempbit != null) {canvasoff.drawBitmap(tempbit,0,1,paint);}
canvasoff.drawLine(w / 2, 0, w / 2, h, paint);
for (
int i = 0;
i < fftint.length - 2; i++)
if (fftint[i] != 0) {
float x1 = i * xInc;
float y1 = scale * fftint[i];
//float x2 = (i++) * xInc;
//float y2 = scale * fftint[i + 1];
int grayscale = h - Math.round(y1);
paint.setColor(Color.rgb(grayscale,grayscale,grayscale));
canvasoff.drawPoint(x1, 0, paint);
canvas.drawBitmap(bitmapoff,0,0,null);
tempbit = bitmapoff.copy(bitmapoff.getConfig(), true);
Panholder.unlockCanvasAndPost(canvas);
one more, The smearing in the above videos, is because of panadapter averaging. Since this waterfall is using fft data, here is a video with averaging off. Looks more like it should.
https://www.youtube.com/watch?v=k8rzWbj96EU
William, this waterfall looks really good to work with.
BTW I'm back from Sicily and the Äolian Islands and 14 days of the best
food and wine...so I'm trying to get back into the ruts again...do you plan to publish a version with waterfall?
73, Alex DH2ID0 -
I love Sicily. I lived there for 2 years back in the mid 90's. I was 21yo back then. Man did I have fun!
Yes I plan too at some point. But its far from ready.
William0 -
I am doing it differently
Had color order wrong. Now it looks just like SmartSDR. Last one today I promise!!
https://www.youtube.com/watch?v=OLfhpcLnWhI
5 -
Getting better and better William! Looking forward to seeing the end results in the Play Store. I'm even willing to pre-order a copy!!! :-)
james
This morning I played around and created a panfall. While this is cool, the drawing really taxes my tablet. This is because of my sloppy coding, but I will fix in due time. This is just an experiment on how to draw it. Sorry for the blurry video, **** iphone 5 camera!
https://www.youtube.com/watch?v=KQqPYU3RzjU
3 -
Just gets better and better! I doubt that I'll ever be where I can add a panafall to my program. But, it will certainly be fun trying. ( I've been digging thru the source code for SDR Sharp and looking at how the panafall is implemented there.)
james
Off topic WIlliam, I found my memory leak! This runs like a scalded cat uses less than 1% cpu. I thought I'd share!
Nice I would like to see it. I have serious memory issues with my code right now. and its churning about 30% cpu. I'm sure I can resolve it with time. All my performance issues are around onDraw, but I will nail them down eventually.
Being new to programming I'm at information overload. Lots to digest, and takes tinkering ad practice till the light bulb clicks on! and you have that "ah ha" moment.
William
James,
One month ago I said the same thing. Keep digging and you will get it.
William
Well, depending on what it is running on 30% may not be so bad. 30% does not tell a lot, 30% of a Cray or 30% of an Apple I. If you do your drawing in SurfaceView then the system will pass the draw off to OpenGL, well, again, depending on what you are running on there may be no GPU to pass off to so Prism would end up doing it, in your case. It is still worth programming it as if there were GPUs. The one thing nice about the Nexus 9, and a huge part of why I bought it, 192 GPU cores. S(er)SDR was the prime motivating factor to get a tablet. Since FRS announced Maestro I now have a nearer target. The difference between what I have and Maestro is mine can be thrown in a suitcase without knows breaking off, it will support however many panadapters your 6000 has. At first glance it looks like SSDR. So, it'll have to be this quarter. There was a reason I deliberately did that. I am not real sure that decision was sound so I may rethink that. I was thinking, too, that it would be prudent to show it to Steve Hicks before any YouTube videos, esp given it's proximity in appearance and behavior.0
True, This is an older tablet
One more for today, Iphone publishing to youtube sucks but its quick. Sorry for the blurry video. This one is a bigger display with 192khz bandwidth.
https://www.youtube.com/watch?v=TzAthtNZxK0
5 -
OK, now I do feel old. I'll have to look up how to upload stuff to youtube. Are all your videos to you're whatever-it-is-others can subscribe-to, or is there a private space you can put things in? Do you have to pay for YouTube hosting?
OK, that couldn't be much easier...channels, that was the term I was searching for.
Its public space, and its free. You can upload directly from your phone. Just use your google account.
Well done, William.
It just keeps getting better and better!
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 774 Maestro
- 42 FlexControl
- 730 Genius Products
- 253 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
