TX LINE SWITCHING
G4YDO
G4YDO Member ✭✭
edited October 2017 in FLEX-6000 Signature Series
recently had my east downs 2m amp arrive. my question can i switch tx2 only for the 2m amp? as at the moment when i press ptt it keys both my 2m amp and the hf amp.
any help please.
paul
g4ydo
  • Scott - K7DSH
    Scott - K7DSH Member
    edited April 2015
    I have been searching  for the answer to this problem and can't see any.  I have the 6700 and the downeast 2M LDPA and the LDPA will key on when I transmit on HF.  Is there a setting somewhere that will fix this?
    Scott  k7dsh
  • Stan VA7NF
    Stan VA7NF Member ✭✭✭
    edited February 2017
    I find the same thing as well.  Also the case when I have the DEMI turned on and key the HF amplifier; the DEMI is also keyed.
    Don't have the equipment but this logic also implies that if there were 2 or more amps/transverters they would all be keyed.
    Even if we could individually trigger these lines, XVTR Table or similar, there are still only so many TX lines available.
  • G4YDO
    G4YDO Member ✭✭
    edited May 2015
    if i disable tx1 the hf amp and enable tx2 the 2m amp all ok, but as soon as i change band all the tx lines are enabled again. can save this in any way?
  • pa0bie
    pa0bie Member
    edited April 2015
    Alright a year ago i asked for a possibility to assign the TX1 , TX2 , TX3 and the ACC.TX to a specific band and or mode , just as with the FLEX 5000 and PSDR.  Tim promised this option for a feature releas of SSDR.
  • Scott - K7DSH
    edited April 2015
    Thanks for the replies. I guess we need an update from FlexRadio. Tim, can you update us on a solution to this? If and how and when? Thanks. Scott
  • Tim - W4TME
    edited March 2017
    This defect is still in our bug tracker. I do not have any information on when it may be addressed.
    For now, you will need to manually set the TX Relay settings manually.
  • G4YDO
    G4YDO Member ✭✭
    edited May 2015
    great only  been waiting 9 months!
  • Scott - K7DSH
    edited April 2015
    Thanks for the update Tim.  It  would mean a lot to us if someone would take a look at fixing this.
    Scott
  • Rich - N5ZC
    Rich - N5ZC Member ✭✭✭
    edited October 2017
    Any updates on this.  I have a 6700 setup in an SO2R environment.  I'd like TX1 to follow slice A and TX2 to follow slice B.
    Rich - N5ZC
