TX LINE SWITCHING
G4YDO
recently had my east downs 2m amp arrive. my question can i switch tx2 only for the 2m amp? as at the moment when i press ptt it keys both my 2m amp and the hf amp.
any help please.
paul
g4ydo
any help please.
paul
g4ydo
2
I have been searching for the answer to this problem and can't see any. I have the 6700 and the downeast 2M LDPA and the LDPA will key on when I transmit on HF. Is there a setting somewhere that will fix this?
Scott k7dsh
I find the same thing as well. Also the case when I have the DEMI turned on and key the HF amplifier; the DEMI is also keyed.
Don't have the equipment but this logic also implies that if there were 2 or more amps/transverters they would all be keyed.
Even if we could individually trigger these lines, XVTR Table or similar, there are still only so many TX lines available.
if i disable tx1 the hf amp and enable tx2 the 2m amp all ok, but as soon as i change band all the tx lines are enabled again. can save this in any way?
Alright a year ago i asked for a possibility to assign the TX1 , TX2 , TX3 and the ACC.TX to a specific band and or mode , just as with the FLEX 5000 and PSDR. Tim promised this option for a feature releas of SSDR.0
Thanks for the replies. I guess we need an update from FlexRadio. Tim, can you update us on a solution to this? If and how and when? Thanks. Scott1
This defect is still in our bug tracker. I do not have any information on when it may be addressed.
For now, you will need to manually set the TX Relay settings manually.0 -
great only been waiting 9 months!
Thanks for the update Tim. It would mean a lot to us if someone would take a look at fixing this.
Scott
Any updates on this. I have a 6700 setup in an SO2R environment. I'd like TX1 to follow slice A and TX2 to follow slice B.
Rich - N5ZC
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 769 Maestro
- 42 FlexControl
- 729 Genius Products
- 394 Power Genius XL Amplifier
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
